Winterization
Old Dec 7, 2010 | 07:41 PM
longawaited's Avatar
longawaited
Default Winterization
Hi everyone.
I just purchased a 2011 Electra Glide Classic. I was just wondering if any of you folks winterized your bike. All the bikes I have had in the past I would just start them up a couple times througtout the winter and let them warm up. Thanks
Old Dec 7, 2010 | 07:49 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
a little stabil in the tank and ALWAYS on the battery tender,some will cover, if u do use a sheet anything plastic will trap condesation.make sure theres no pool chemicals in the garage it will eat chrome fast.
Old Dec 7, 2010 | 07:52 PM
07RoadHawg's Avatar
07RoadHawg
IF I was going to winterize my bike, I'd put fresh fluids in it, stabilizer in a full tank of fuel, put the battery tender on it and not touch it until it's time to ride in the spring. I've always been taught and believe that starting a motor (any motor) and idling it does more harm than good. You are letting moisture blow by the rings at idle and even though you may think you are getting it warm enough to burn off, you aren't. Even if you were, moisture is still getting by the rings and in to the cases at idle.
But that's just me. Everybody has an opinion....
Old Dec 7, 2010 | 07:58 PM
flhxkiller's Avatar
flhxkiller
fresh oil in all holes, stabil and full tank of gas, put it on a battery tender and cover it up. I don't start it till I'm gonna ride it, usually sometime in March.
Old Dec 7, 2010 | 08:00 PM
tall jerry's Avatar
tall jerry
also put it on a 4x8 piece of plwood or on some carpeting you don't want no flat spots on your tires.
Old Dec 7, 2010 | 08:01 PM
tincup64's Avatar
tincup64
same here, stabilizer, battery tender. dont worry about fluids until i would do them anyway. if i were to cover it, i would use a couple of cotton sheets. wish i didnt even have to think about winterizing.
tin
Old Dec 7, 2010 | 08:19 PM
rscott's Avatar
rscott
My thoughts exactly
Old Dec 7, 2010 | 08:36 PM
dboyenga's Avatar
dboyenga
Agreed, starting the engine for a warm-up in the winter is far worse for it than just letting it sit... a mechanics instructor.
Old Dec 7, 2010 | 08:39 PM
'05Train's Avatar
'05Train
I rarely ride the 'Train in the winter, I ride the Limited at least once a week. Neither one gets winterized, they just go on the battery tender. There's no need to do anything else. Do not start the bike unless you plan to ride it for at least half an hour to get everything up to operating temperature.
Old Dec 7, 2010 | 08:40 PM
CEJohnson21's Avatar
CEJohnson21
I've never used Stabil, and I don't even own a Battery Tender. In the winter months I just ride it a couple of times per week. A ride anywhere from 2 hours to 2 days. This helps keep the battery charged and the gas fresh.
