gas tank fit
Old Dec 9, 2010 | 10:24 PM
Soldier of Misfortune's Avatar
6th Gear
Default gas tank fit
Im trying to find out how I can make 07 street glide gas tank work on a 95 ultra classic. Mainly the fuel pump and the fuel gauge. Also can I put an in line pet **** on the fuel line and expect fuel to flow freely.
Old Dec 10, 2010 | 12:13 AM
sifularson's Avatar
sifularson
I highly doubt that you can make an injected tank work on a carb bike.
I might be wrong . . . an expert is bound to chime in eventually.
Old Dec 10, 2010 | 01:51 AM
Gutman's Avatar
Gutman
Why not? Fuel flows according to gravity and last I checked, both tanks are located above the throttle body or carb. An inline fuel valve will be needed and leave the top plate on.
Old Dec 10, 2010 | 07:21 AM
grbrown's Avatar
grbrown
Thumbs up
I don't regard myself as an expert! But it can be done and I have done it. I have a recent 6 gallon tank without the efi stuff that goes inside and used a Pingel gas tap and adapter. They make an adapter for both single and twin outlet tanks, plus a blanking plug for the spare hole in early twin outlet tanks.
With a Pingel tap fuel flow should be better than the stock tap. I haven't solved the fuel gauge yet on my 1990 FLHS yet, but am thinking of cutting a hole in the top of the tank to take my original one.
Old Dec 10, 2010 | 09:15 AM
6th Gear
is it possible to use the fuel pump in the gas tank for the carburetor. what about using a regulator to regulate fuel flow to the carburetor while using the fuel pump
Old Dec 10, 2010 | 09:19 AM
6th Gear
g rbrown on my 95 I just plugged the fuel gauge wire into the back of my gauge in the fairing, I don't know how your 90 is
Mscott921
General Topics/Tech Tips
Dec 18, 2016 01:54 PM
DownSouthSportn
Mar 8, 2009 11:15 AM
Longhauler
Jul 9, 2007 08:50 PM
jimmerdn
Exhaust System Topics
Jan 1, 2007 10:43 AM
Beefcake
Dec 13, 2005 09:11 PM
