21" Tire Size Diameter Increase?
Old Dec 12, 2010 | 10:35 AM
slammd's Avatar
slammd
Default 21" Tire Size Diameter Increase?
By going to a 21" wheel, can I expect the overall tire diameter to increase? I expect it may be somewhat different for the various tire manufacturers but am trying to understand if it will elevate the front end of my bike? Thanks
Old Dec 12, 2010 | 11:59 AM
103Eagle's Avatar
103Eagle
Well stock is 16, 17, 18, or 19, depends on year and model to which you did not specify. Think about it, 21 is just a bit larger, dont ya think that will change the diameter of the tire as well? Of course it will, take half the difference in diameter of your tire and the 21 replacement and that will give you how much it will raise your front end. Figure at least 1 1/4" raise, thats why many guys lower the front end after installing the 21s.
Old Dec 12, 2010 | 12:23 PM
DTTJGlide's Avatar
DTTJGlide
The 21s range from 27.8 to 29 compare that to stock which is 25.5, so you're going to have to do something to make up for that increase. I prefer 18 or 19" since they stay within a 1/4" of same diameter.
Old Dec 17, 2010 | 02:51 PM
pit1600's Avatar
pit1600
it will elevate a little but nothning noticeable
Old Dec 17, 2010 | 03:41 PM
1bagman's Avatar
1bagman
If you go to a web page like tirerack.com you can look at charts that will give you the outside diameter of the tire you are looking at. You will see that the 21" with it's low profile side wall isn't that much taller than the stock harley 16" tire. I lowered the front of my bike because I need all I can get at 5'6".
Dew Me
Aug 12, 2018 09:16 PM
RPG485
Apr 23, 2016 08:25 AM
Sinner77
Jun 19, 2014 09:36 PM
stbobfisher
Sep 22, 2010 04:47 PM
El Chiguete
Wheels/Tires
Aug 28, 2010 09:19 PM
