Installed lowering kit and jacked up the rear harness after one to many hard hits. I bought the harnes today for 25 bucks from the dealer question is....How do you take of the fender? Is this a DIY job?
Remove seat, saddlebags.
Unplug rear harness.
Remove bottom shock bolts.
Raise rear of bike, just enough to lift tire off ground.
Remove lowering kit. (unless you want to do this again)
Reach under fender and from the front free harness from tabs.
Remove tailight and fender tip light.
Start from the back and reinstall.
Be patient. Hope you have a heated garage.
Reason: I may have forgotten a couple of things.
