Master cylinder leak
Old Dec 30, 2010 | 10:41 AM
MILLER41143's Avatar
MILLER41143
Default Master cylinder leak
i just got finished w/ my new ape install from hcc
but i am having a very tiny leak o fbreak fluid where the cable screws into the master cylinder around the bamjo fittings
does anyone have any advice on what i need to do
i used the brass or copper washers from the factory setup
Old Dec 30, 2010 | 11:10 AM
roadgliderick's Avatar
roadgliderick
replace your copper washers.
Old Dec 30, 2010 | 12:06 PM
MILLER41143
good deal ill try that
is that something that is universal, cause i have some from a set of galfer brake lines that are new
Old Dec 30, 2010 | 12:27 PM
sgdiesel's Avatar
sgdiesel
You should replace the washers each time, as suggested. The washers are soft and you cut a groove in it when you tighten the fitting. If you re-use then you run the risk of the groove not lining up and leaking.
In terms of universal, any copper washer that is the same size will be fine
Old Dec 30, 2010 | 12:30 PM
roadgliderick
as stated above as long as they are the same size.
Old Dec 30, 2010 | 02:01 PM
MILLER41143
thanks !
hobo1
Mar 20, 2012 05:30 AM
dwint
May 9, 2011 02:14 PM
twizted81
Wheels/Tires
Apr 4, 2010 08:21 AM
jammer1
Jun 28, 2007 12:10 AM
utz
Apr 22, 2007 10:40 PM
