Bagger brace. Your thoughts
just my own personal $ 0.02,
corb
corb
What convinced me was when I upgraded my friends 2000 RK with a complete 07 swingarm etc. with new HD bushings. I honestly could not believe how nice it handled, better than my 05 with 45K on the original bushings and a Bagger Brace. My guess is when I put the BB brace on I could have just replaced the stock bushings, skipped the brace and would have seen an improvement equal to the BB. I just think the original bushings deteriorate to quickly.
Rick
Rick
check 6, cause soccer moms on cell phones are more dangerous than bullets...
corb
corb
Rick
The purpose of the third stabilizer is to provide lateral support to the rear engine mounts. They remain rubber, even if you installed one of the bushing kits you mention. Early rubber mounts also had rubbery 'cleve block' swingarm bushings, which were a serious handling problem and were replaced with more solid bushings way back. You may be confusing those with the bushings you have recently installed.
The only reason stabilizer kits, such as True-Track, are compromised is because Harley didn't incorporate them into our bikes on the production line, like they did on Buells and Sportsters. The makers of our kits (and at the last count there are around a dozen brands) have to overcome two problems: 1 is avoid copying the others, and 2 is to get around the problem of retro-fitting something the factory should have built in from Day 1. That is the only reason why some of them stick out below the frame.
Some of the dozen brands IMHO seem to miss the point of the third stabilizer, but the True-Track appears to have been first on the scene and come closest to achieving what Erik Buell intended. They get my money and I have them on both my big twins, which share my garage with a Buell. All three of them have three stabilizers - it's the only way to travel!
but yes, you are correct, as far as i know, in the 3 rd stabilizer. but i replaced the cleve block style rubber "bushing" (that was in the swing arm mount on my 2000 road king) with solid bearings, as i used the swing arm off of my 2004 (that had spherical bearings.... and a bigger 3/4 inch swing arm pivot shaft) but i replaced the rubber motor and trans mounts with urethane bushings, and the rubber bushings, on the outside of the swing arm pivot mount, were also replaced by urethane. further aiding in solving my handling woes. thus negating my need of a true trac, bagger brace, or any other extra link, between my motor, trans and swing arm. thankfully so, as well, because i was always worried that i was going to tear mine off hitting big pot holes, or speed bumps in parking lots.
the only thing that i have not done to further aid in my bagger's handling woes, is lock up the front end. i used a fork brace, off of a dyna on my old 2004. but running without the cans, and the look were things i did not want to repeat. so, i am about to order the pinch bolt set up, also from custom cycle engineering, so as to lock in my front end, without the use of a fork brace. i dont know if anyone else is using one, but i ll tell you all how it works out for me.
sorry for the confusion,
corb
Rick
Rick
