Bagger brace. Your thoughts
Old Jan 5, 2011 | 01:19 PM
denalion22's Avatar
denalion22
Default Bagger brace. Your thoughts
So I just ordered one of the bagger braces.
Has anyone had any experience with these.
Did you like them did you not. And did they change Tge handling much?
Your comments are appreciated.
Old Jan 5, 2011 | 01:27 PM
andyp's Avatar
andyp
Put one on my 04 Flhtc a couple of yrs ago,Love it ,bike handles much better.At first I could feel a slight bit more vibes,but after a couple of rides it smoothed out.My buddy put one on his 06 and also noticed a difference in handling. There are many other stabilizers out there and from what I have read,they all work,but for the money spent on the Bagger brace,you cant do much better.My bike is lowered with bagger brace shocks 1.5 in in rear and that was the other reason I went with it because it tucks inside frame.
Old Jan 5, 2011 | 01:30 PM
denalion22's Avatar
denalion22
Cool thanks. Anyone else have good words. I'm trying to justify my purchase. Lol and to make sure it's worth it
Old Jan 5, 2011 | 02:08 PM
SA315B's Avatar
SA315B
Removed mine after 3,000 miles or so, I have a Glid Pro now. I think it is worth the extra money, certainly better than the Bagger Brace.
Old Jan 5, 2011 | 02:12 PM
pauletich's Avatar
pauletich
Had one added about three months ago on my 07 FLHX. I must say it has helped a lot. The handling has improved and I am more confident and stable in sharp turns. Well worth the money IMO.
Old Jan 5, 2011 | 02:17 PM
qtrracer's Avatar
qtrracer
I have a stabilizer(not a Bagger Brace) on my 2008 FLHX and I have 13" Ohlins and ride a little harder than the bike is designed to be ridden and the brace does it's job. It cannot fix an out of alignment frame/eng/trans or bad shocks/tires.
Old Jan 5, 2011 | 02:24 PM
ohioflhs's Avatar
ohioflhs
My 2008 EGC had one on it when I bought it. Don't know how much it does, but I can't use my jack because it hangs lower than the frame. It scrapes the ground sometimes. Other than that it is probably ok.
Old Jan 5, 2011 | 02:53 PM
Grey07's Avatar
Grey07
5th Gear
I went with progressive Touring link after seeing posts on the ground clearance - also have Glide Pro setup also makes for night and day difference handling machine
Old Jan 5, 2011 | 02:59 PM
denalion22's Avatar
denalion22
Great this is what I have 07 SG. I am very impressed thus far and it's not even in my hands. Yet. I will let you guys know what I think I hope Friday.
Old Jan 5, 2011 | 03:14 PM
tj316's Avatar
tj316
I had the Bagger Brace on my Classic and it helped alot, I would get a high speed wobble before ,after problem solved
