Trailering
Old Jan 7, 2011 | 01:09 PM
howa's Avatar
howa
Default Trailering
Just bought a folding trailer from Harbor Freight to pull my '06 FLHTCI 3-4 times a year. Anybody have any trailering experience, advice, or suggestions that they'd like to share? Also, looking for suggestions on a ramp.
Old Jan 7, 2011 | 01:20 PM
CWDoc115's Avatar
CWDoc115
First up, what's the weight limit on the trailer? It should be able to hold 850 - 1100 lbs of combined vehicle weight + whatever stuff you will be packing in the bike. As to ramps, check out Ramps USA on the internet,
Old Jan 7, 2011 | 01:31 PM
sooie's Avatar
sooie
make sure you have a spare tire/wheel for the trailer
Old Jan 7, 2011 | 01:36 PM
EasternSP's Avatar
EasternSP
I think you will have preferred a lower center of gravity trailer. That one looks like it would be fine for hauling furniture, boxes or tree limbs, but put a bagger up there and it might be kinda top heavy.
Also, always have it hitched properly to your vehicle when loading the bike.
Old Jan 7, 2011 | 02:00 PM
Beemervet's Avatar
Beemervet
Sorry, but I wouldn't put my bike on that trailer for out of town trips.
Old Jan 7, 2011 | 02:20 PM
MILO851's Avatar
MILO851
I bought the smallest trailer menards used to sell years ago i put a rail down the center for hauling bike worked great! not a problem i put eye hooks in all corners. made a removable ramp to go on the trailer same length was good set up
Old Jan 7, 2011 | 02:33 PM
FDHOG's Avatar
FDHOG
Something about the word "FOLDING" scares me.
IF you insist on using it to haul your bike, put tiedowns in all four corners and mid-way on the sides and get a good front wheel chock.
Old Jan 7, 2011 | 02:38 PM
chevele72's Avatar
chevele72
I have the same trailer, I welded all the bolted sections, and it won't fold anymore. I used to tow an electric golf cart to car shows on it. No issues on I-4 @70mph. (I put bigger tires on it) It's a tilt trailer, don't know how that would work with the bike. The golf cart is gone now but still have the trailer.
Old Jan 7, 2011 | 02:46 PM
Jinks's Avatar
Jinks
You can find an inexpensive removable wheel chock for the front that'll work just fine. Add eye bolts for two pair of tie downs at the front, & a single pair at the rear. The two pair at the front need to have separate anchor points! Two tie downs on a single point are useless if the anchor point fails! The ones at the rear are just to keep the bike straight, & don't get much strain.
Use ratchet straps *only* on hard points of the bike! Ratchet straps will break handlebars & bolts! Friction straps are strong enough to tow a bike. Only use ratchet straps if you have to, & are on hard points on the bike.
Old Jan 7, 2011 | 03:01 PM
rstekeur's Avatar
rstekeur
1195 Lb. Capacity, 900lb bike + 159 lb trailer. that's close to capacity
