You shouldn't lose anything at all. The saw blade will take at most 1/8 " The Welder should leave a gap for the filler rod.
Not a professional welder but I dont see how you could leave a gap when welding thin mat'l.
The width of the cut can be minimized by using a band saw.Butt it up and tig weld.
i used a band saw to cut mine, and didn't worry about the material loss when welding it back together. there is plenty of room for adjustment where the slip on mounts.
You should at least talk to a professional welder. You never want to butt solid against anything. Heavy pipe or thin exhaust pipe. The reason they keep a small gap, maybe 1/16 in a case like this, so the filler rod can penetrate and fill like it's designed too. If you don't leave a space for the filler rod to penetrate, Then the weld will probably crack.
