2006 Ultra
Anyone know what the OEM shock capacity is? I filled my shocks with new oil yesterday and put in 11 ounces (325 milliliters) but perhaps it should have been 12 ounces (354 milliliters). Should I add another ounce?
2006 Ultra
Thanks
You should be good where you are. My '07 takes 10.8 oz. (11.1 for RK) and '06< should have the same spec. I'm sure someone with an '06 can verify this.
texasbowhunter's post on changing the shock fluid ("making the stock shocks better" I believe was the thread title) should give you some insight on the fluid amount.
The 13 in
The 13" Showa shocks on my 07 RK take 12 oz. I think these shocks are the same as yours. I'm not sure that being 1 oz under filled makes a big difference. You could just try them and see how they feel and if you're not happy, add another oz.
