Accessory Switch
Old Jan 18, 2011 | 05:00 PM
sanlyn's Avatar
sanlyn
Default Accessory Switch
I'm looking at some of the Kuryakyn auxillary lights for the Road Glide. I don't like the cheesy toggle switch that comes with the lights, and would prefer to wire it to an accessory switch mounted in the blank spot to the right of my ignition switch. I don't have a Touring parts manual, can anyone give me a part number for the switch that would replace the blank? I suppose it would be the same part number as the accessory switch already wired to the right side of the ignition switch.
Old Jan 18, 2011 | 05:12 PM
mkguitar's Avatar
mkguitar
part number for the HD switch what says "Spots" : 71505-96- that is what is used on the FLHT series
retail about $26
you might find this link handy:
partsfinder.onlinemicrofiche.com/ronnies//hdm_oem/hdmc.asp?Type=13&A=548&B=45
Old Jan 18, 2011 | 05:19 PM
Ronp42's Avatar
Ronp42
Account Retired
according to my 2010 part's book, the accessory switch for your bike is part# 71535-96 It's together on a plug with spot light switch # 71505-96
Old Jan 19, 2011 | 03:44 AM
Ultra89Rider's Avatar
Ultra89Rider
I installed the Kuryakyn double throw switch in my nacelle. I moved the odometer reset button to between the gages. Then I cut the hole the same size of the switch and installed the double throw switch. I am using one side for the Kuryakyn Spotlights. The other side is for future use. (I will install LEDs over the motor)
Old Jan 19, 2011 | 08:37 AM
sanlyn's Avatar
sanlyn
retail about $26
Great link, thanks. It looks like the switches are attached via a harness. I suppose I could buy a separate switch and wire it independently, but wonder if the wiring is already present for a power source?
soulpatch
May 27, 2019 01:14 AM
Drtumolo
Audio Systems
11
Jun 26, 2017 05:24 PM
just plain john
Nov 23, 2014 07:24 AM
Am4wag
Jul 1, 2013 05:12 PM
ONLYTNT@YAHOO.COM
Sep 19, 2009 12:49 PM
