That's a really smokin deal!!! Does your supplier offer the same light with just the dual function? Not a real big fan of the turn signals in the same housing as run/brake light.
Thanks and if you don't want the turn signal function, just don't connect the turn signal wires ( 2 yellow wires). Then the tail light will just works only on running light and brake light.
Will ALL the LED's light up this way, or will the ones for the turn signals be wasted? There aren't that many lighting up in the brake/run mode in the video.
[QUOTE=D2MOTO;7811362]Thanks and if you don't want the turn signal function, just don't connect the turn signal wires ( 2 yellow wires). Then the tail light will just works only on running light and brake light.[/QUOTE
Is there a way utilize the turn signal LED's for the brake/running light if the turn signal wires are not connected???
I would think that all you would have to do is hook them up to either wire running the brake or running light function and you would be good. Think I am going to order one and play with it. Those BAL's are to much cheese
Sorry that the answer will be no, because our new design tail come with the flashing module on the turn signals LED (ember LED).
Thank you for your interested about our tail light. I haven't seen the brightness of BAL tail light in person (only saw from youtube video). But I can guarantee that you won't be disappoint about our tail light brightness.
