choosing the right gloves
Old Jan 22, 2011 | 11:34 PM
Udawg's Avatar
Udawg
Originally Posted by BadPiggy
Gerbing or HD for heated gloves.
HD are made by Gerbing and carry the same lifetime warranty.
For non-heated gloves, I use a brand called Olympia.
http://www.olympiagloves.com/
I think the key to fitting gloves for warmth is not buying them too tight.
I actually found just the opposite for me. I normally wear a Large glove and got the Gerbings in a Large. While riding the palms were very warm but the top of the fingers were not. I could press my fingers up against the levers and they would warm up. I figured the air between my fingers and the gloves was keeping me from getting warm. I swapped them for a medium and they work like a charm now. The top of my fingers are almost as warm as the palm. I guess it's different for everybody but for me buying a smaller size was better.
I also like the Olympia when it's not too cold.
Old Jan 22, 2011 | 11:37 PM
CasaWolves's Avatar
CasaWolves
go to the gerbings outlet...great deal on the heated stuff. its the best.
http://heatedclothingoutlet.com/index.shtml
Old Jan 23, 2011 | 12:51 AM
mfuchs2004's Avatar
mfuchs2004
I've got too much Swede in me so I ride in jeans and non-heated gloves at 35 degrees. Once my fingers finally get cold, they stay that way for hours it seems.
I think you're spot on that heated gloves will be warmest if your skin stays in contact. If you have unheated gloves, I find that too snug seems to make my fingers cold. A little air seems to help.
I also find that relaxing my grip when possible helps a lot. I kind of miss that cheap thumbscrew cruise control because I could stiffen that bad boy up enough to relax in the cold. My plastic cramp buster slips when it gets cold.
I have several riding buds who swear by Gerbings. One just plain wore a pair out and sent them in for repair. Gerbing sent him a brand new pair of the microwire units with a letter thanking him for his patronage - no charge. You could use them to make coffee on their high setting.
Old Jan 23, 2011 | 06:18 AM
cochon's Avatar
cochon
I go to the military surplus store and buy the leather shells with the wool liners. When it gets really cold, I slip one of those chemical hand warmers into each glove. Works for about 8 hours and doesn't break the bank.
Old Jan 23, 2011 | 07:33 AM
rapz's Avatar
rapz
I have lots of pairs, but the best for me has been BMW Winter riding gloves or get the heated grips.
Old Jan 23, 2011 | 07:46 AM
SleeplessinVegas's Avatar
SleeplessinVegas
$10 glove liners from Bass Pro Shop work in leather gloves for our high 30-40 degree temps we get here.
Old Jan 23, 2011 | 10:05 AM
"Big E"'s Avatar
"Big E"
Thanks top all that replied, I have the olympia gloves, but they are tight. Guess I should have got the 2X. mine are xtra large. the 2X harley gortek gloves fit better. she told me the same thing, tou dont want a tight fit. Im sure somebody in our group {just joined 2 months ago} has a bigger pair for me to try, and get $10 liners. that will be worth a try first before I dive in on the heated gloves.my hands have always been cold when most others with me are not. just last night, after hunting, my fingers were freezing with gloves on after riding 4 wheeler, everyone else was fine. Anyway,thanks for the info, this forum is awesome! for nubies like me. Im sure i will check out the gerbings sight and end up with some heated gloves, I sure would dhate to miss all those pretty days just because its 35 - 40 degrees. again, thanks a bunch, now maybe I wont waste no more money.
Old Jan 23, 2011 | 01:20 PM
Udawg's Avatar
Udawg
Most of the stuff in the outlet is either the old technology or ultra small.
Old Jan 23, 2011 | 01:23 PM
Udawg's Avatar
Udawg
I think BadPiggy is right on "Non-heated" gloves buying them larger makes them warmer but on heated gloves, I think it's the other way around.
Old Jan 23, 2011 | 04:29 PM
'05Train's Avatar
'05Train
Ain't nothing better than Gerbings when it's really cold.
If you don't want plug-in, I can recommend the Lee Parks Designs DeerTours PCi gloves. They're stupid expensive (too expensive), but they work phenomenally well from the high 30s up to the low 70s.
