SE 255 Cams ONLY
This is real world experience, not what I think will happen. I tried the different configurations and can say a set of 255 cams, a TTS and then down load the file in the TTS files and you will have a winner for what you want. PM me if you want to talk more. Greg
In your case, where you're doing a typical stage II upgrade, there's a whole lot of options open to you. You could do the ECM stage II download from your dealer for about 150 bucks. Or you could run a Power Commander with a map designed for your configuration, which wouldn't be hard to find. Or you could go the dyno tune route as well, which would cost more, but offer the best performance.
That is to say if you run flat out light to light, or constantly live on the high end of the band, a 255 will not make you happy...
however, if you need a low end torque cam, that comes on early, and stays on all the way to 5k, but flattens out above 5k, then a 255 might be your ticket...
They are especially good bolt-in cams for otherwise stock engines with Stage 1 mods in heavy touring bikes. If properly tuned and allowed to breathe (free-flowing intake and exhaust), they will provide a very flat TQ curve and do pull all the way out to the redline. The peak-HP improvement may be along the lines of 4HP, while TQ should increase by 8-10 at it's peak over an otherwise-equal Stage 1 bike with stock cams. Almost any other performance cam set you can name will produce more peak-HP than 255's, but some riders don't hang-out above 4000rpm often and would prefer the power below that point. For me routinely going above 4000rpm is unnecessary since I have all the power I need below that. YMMV. They can also be commonly seen on Ebay as low-mileage CVO pulls for around $150, so IMO the bang-for-the-buck factor is high for these cams, especially if you do the work yourself.
The 204's are a good option too, IMO, but compared to 255's and given stock 9.2 compression they will not produce quite the oomph in the low-end and will put the power higher in the band. It's all in what you want and where you want the power. I do feel that ideally 204's need a bit more compression than the 9.2:1 most of us start out with, but I'm told 9.5-10.0 or thereabouts is a good range for them. The 255's do well at 9.2 on up to 10.0, but toward the higher part of that range (specifically 10.0) they may have problems with hot-starting due to the very high CCP they produce. Based on what I read in the forums some do but most don't.
