help with power commander maps
ORIGINAL: bdg
thanks for the help--I'm just not sure about the accellerator pump thing. Seems like everything I have read on this forum says to turn it off.
I used the fuelmoto's map for while but seemed to lack in power and had very little power in about 60MPH range, so I tried the PC3 map and it runs a lot stronger in all the rpm ranges. Every bike is different so it is good to try different map setups.
Read this one https://www.hdforums.com/m_78884/tm.htm
and this one https://www.hdforums.com/m_803107/tm.htm
Quint, Thanks for the compliment on the Ultra. She has definitely been a work in progress. I made the mistake of not ordering from FuelMoto but they have still been generous enough to offer support. The D&Ds are my 4th set of pipes since I bought the bike. I have emailed Jamie at FuelMoto each time I have changed them and he has sent out new maps for me to try. When you order from them, you will supply them with the info on your upgrades and they will preload the appropriate map for you. If you should make changes somewhere down the line, they will provide updated maps to you. As for feeling a difference in the bike, the D&Ds definitely made a difference. Much more torque in the lower rpms. I am very happy with all 3 upgrades combined but not happy enough that I will stop upgrading. I think there is a 98 kit in my future. LOL Good luck with the 07. This is my first Ultra but definitely not my last. I love the comfort of my bagger.
You have one mighty fine looking sickle. When you bought your PCIII, did you specify the D&D exhaust and Big Sucker air filter? Did Fuelmoto then give you a custom map? Also, did the seat-of-the-pants ride feel faster? I am about to order an '07 Ultra and it needs a map/pipe/air filter to up the power and enrich the AFR. Thanks, Quint.
