help with power commander maps
Old Oct 3, 2006 | 06:53 PM
bdg's Avatar
bdg
Default help with power commander maps
ordered power commander from fuel motto and asked if I should use the map off of dynajet web site. They told me no, they had there own maps they used that where better. Is this true? Also do I need the acellarator pump option on or off for a fuel injected road glide?
Old Oct 3, 2006 | 07:03 PM
rollover's Avatar
rollover
Default RE: help with power commander maps
They probably sent the pclll with the correct map on it already for your particular setup. I have an 06 FI Ultra and don't use the accellerator option. I think most don't use it.
Old Oct 3, 2006 | 07:06 PM
bdg's Avatar
bdg
I guess I thought the accel pump option was a good thing.
Old Oct 3, 2006 | 07:17 PM
bountyhunter's Avatar
bountyhunter
It is!
Old Oct 4, 2006 | 01:20 AM
Bushman's Avatar
Bushman
Stage I
Use the MAP Fuelmoto installed. I tried the Power Commander map for my setup and the Fuelmoto one was far superior on the
butt-dyno.
Old Oct 4, 2006 | 03:11 AM
quint's Avatar
quint
ORIGINAL: rollover
You have one mighty fine looking sickle. When you bought your PCIII, did you specify the D&D exhaust and Big Sucker air filter? Did Fuelmoto then give you a custom map? Also, did the seat-of-the-pants ride feel faster? I am about to order an '07 Ultra and it needs a map/pipe/air filter to up the power and enrich the AFR. Thanks, Quint.
Old Oct 4, 2006 | 08:59 AM
Jeepin_Lawyer's Avatar
Jeepin_Lawyer
I thought Fuel Moto's map was pretty close; power was good, it didn't feel lean anymore and MPG was really good. Fuel Moto was great to work with.
Next, I added different pipes and I had to change it to a download from PowerCommander's site. . .it runs ok but I need to find a tuner in the next few weeks.
Old Oct 4, 2006 | 09:02 AM
nick@nite's Avatar
nick@nite
I have contacted Fuel Motto 3 different times for new maps because of changes I made to engine.
Whatever mod you make to your engine they have a map ................great people to work with.
nick@nite
Old Oct 4, 2006 | 09:39 AM
bdg's Avatar
bdg
thanks for the help--I'm just not sure about the accellerator pump thing. Seems like everything I have read on this forum says to turn it off.
Old Oct 4, 2006 | 11:11 AM
huffhuff's Avatar
huffhuff
the MAP fuelmoto furnished me works better than any of the MAPs on the PCIII USB software (i tried nearly all of them that were close to my bike's equipment). they are truly the best and I'm not a customer.
