Hog Tunes Install
Old Feb 5, 2011 | 05:36 PM
V2Evo96's Avatar
V2Evo96
Originally Posted by Ribitt
have the same set up on my 07 UC but why is it once the volume gets to half it don't get no louder.
Check your AVC (Auto Volume Control) setting in the menu function of the Harmon Kardon Radio system. It should be set to 3 bars. If it IS set to 3 bars, try reducing the AVC to 2, then 1, then 0 and see if that makes any difference.
My setup works fine on 3 bars, which is the HogTunes recommended setting. Let us know how you go.
Old Feb 6, 2011 | 10:58 AM
ultra_classic's Avatar
ultra_classic
what HogTunes speaker kit to buy to upgrade my 05 Ultra with all factory stuff,
Maybe this is a question for Pez, but for my 2005 Ultra Classic, the "big ultra kit" comes with 2 ohm speakers, and NCA 40.4 amp but my HD deck uses 6 ohm speakers? [2005< =6ohm] does this kit allow the head unit to use the amp to run the new [4] speakers at 2 ohms? or does Pez make a <2005 kit with the 914.2 112.2 speakers for this application?
and if the 2 ohm speakers work, then maybe i should buy the 6 speaker kit instead, 10.00 cheaper, plus i get 2 extra speakers, mounting brackets for lowers etc etc that i could install or not and keep for later install?
Old Feb 6, 2011 | 04:16 PM
V2Evo96's Avatar
V2Evo96
There is a window on the HOGTUNES website in the section 1998-2005 models that has info on amp configuration. My company blocks some info on websites and in this case all I see is a blank window.
Have a look or email PEZ at info@hogtunes.com to answer your query if no one else can assist.
Old Feb 6, 2011 | 09:23 PM
ultra_classic
hi V2evo96 i spent a lot of time in HogTunes website, and that is were i got the info for the question, i guess i will e mail Pez,
But basically 2005> is 6 ohms, and 2006 > is 2 ohm, but the big ultra kit that fits 1998-2011 but contains 2 ohm speakers...so does the new amp power the 4 new 2 ohm speakers, and the 98-05 head unit is ok to power the amp?
Old Feb 6, 2011 | 10:29 PM
V2Evo96's Avatar
V2Evo96
ultra classic-- good point -- on current models the amp powers the front fairing, lower speakers and tweeter pod; and the inbuilt bike radio amp continues to power the rear speakers.
However the newer models are 2 ohm front and rear.
I think you would be OK but best to send a mail to PEZ to ensure accuracy. He should get back to you asap-- always has when I've had a question.
I see your in Ontario (as PEZ is) -- maybe give him a ring?
Old Feb 7, 2011 | 08:56 AM
Ribitt's Avatar
Ribitt
Cool
My AVC is on 4 I will change it to see what happens. Thanks for the tip.
Old Feb 7, 2011 | 09:11 AM
Harleypingman's Avatar
Harleypingman
Yes, HT's new four-channel amp drives the two fairing speakers and two rear speakers with 2 ohm impedance. The amp doesn't care that the head unit in the '05 and older models is an 8 ohm impedance system.
Carl
patbernotas
Audio Systems
May 29, 2015 11:06 PM
JMJOHN
J&M Motorcycle Audio
20
Apr 13, 2014 06:11 PM
hdman6
Feb 17, 2012 04:44 PM
creep1
Mar 16, 2009 11:18 AM
NATESBPD
May 20, 2008 12:58 PM
