wind deflector
The wind deflector that is between the forks under the lower triple tree, does that make a noticible difference? On my dyna i have a windshield and it works pretty good, i dont have a big problem with buffeting like i hear alot of people talk about, but i get a lot of air rushing up between the tank and handle bars.
So i was wondering if that little wind deflector would help with that. I dont think i have ever seen one on a dyna but I'm sure one could be made to fit somehow.
I picked up a used one that I was thinking of putting on my 2010 103 Limited.
I was trying to come up with a way to install it with some sort of quick disconect fasteners that way I could remove it quickly as the weather nears 70 degrees and reinstall it on cooler days (kind of like chaps).
I hoped the deflector you're talking about would help with buffeting so I bought and installed one. Honestly, I don't notice any difference at all. I don't think the wind causing buffeting is coming in between my fork legs, I think it is coming over the outside of my forks (over the left and right side of my tank).
A company called Freedom Wings (I'm not associated in any way) makes air deflectors for batwing farings (like the ones now standard on the Ultra; however, they also make Freedom Wings Plus. These are smaller plexi deflectors that fill the gap that air passes through on the outside edges of the upper fork legs. See: http://www.freedom-wings.com/Plus_Facts.html
I bought and installed these (about $25) and they make a big difference. I also replaced my stock batwing air deflectors with the Freedom Wing product (about $75). I did this because the bottom deflector mounting hole on my Ultra was used as one mounting point for the stock deflector and I needed the hole to mount the Freedom Wing Plus (the aftermarket batwing deflector doesn't use this bottom hole). I probably could have "modified" the stock deflector so it would not use the bottom mounting hole but I like the looks and the function of the Freedom Wings (especially together with the Freedom Wings Plus).
Back to your Dyna, perhaps the fork leg deflectors (that I think work like the Freedom Wing Plus) would be a better solution for you than the deflector that goes between the forks (here's a link to an aftermarket pair - HD also sells deflectors like these): http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
Good luck! Bob
