Bagger gauges
Old Feb 5, 2011 | 01:47 AM
luisan's Avatar
luisan
Default Bagger gauges
As usual I have a question for you guys and hope you can help me again.Will a set of 2010 gauges from an FLHX fit and work in my 2006 Ultra?Thanks
Old Feb 5, 2011 | 03:43 AM
KaponeWKYA's Avatar
KaponeWKYA
I'm fairly certain they should...I gave my gauges from my 08 to my buddy for his 05 and they worked out no problem...
Old Feb 5, 2011 | 05:44 AM
luisan's Avatar
luisan
So why there are so many different part numbers for different model year in the HD catalog?I'm a little confused and trying to avoid buying something I couldn't use.Thanks
Old Feb 5, 2011 | 05:56 AM
SE120RG's Avatar
SE120RG
I'm pretty sure the fuel gauge will not due to the change from 5 to 6 gal in 08. the tach should but I would also be concerned about the speedo since they may have changed final drive ratios and I think the speedo reads off the tranny.
Old Feb 5, 2011 | 06:24 AM
Iceman24's Avatar
Iceman24
Different wiring/connections - some of the std ones will work, but others won't. If you're dealing w/someone you know - try them out for fit/functionality...
V-Twin-Power
Jan 18, 2021 11:27 AM
Mchad
Jan 21, 2017 07:19 PM
Bakdrft
Apr 23, 2013 12:48 PM
oliver99
Feb 15, 2012 03:23 PM
oliver99
Jan 24, 2012 12:39 PM
