04 Road King Custom
Old Feb 6, 2011 | 10:03 PM
Superbob's Avatar
Superbob
Default 04 Road King Custom
Is the 04 RK have carbs is it fuel injected? Any problems to look for? Thanks.
Old Feb 6, 2011 | 10:04 PM
BadPiggy's Avatar
BadPiggy
It could be either.
Old Feb 6, 2011 | 10:06 PM
krwould's Avatar
krwould
I have an 04' RKC... 28000 miles, changed the cams to gear drives last year, runs great and is fuel injected....
Old Feb 7, 2011 | 05:33 AM
smokehiker's Avatar
smokehiker
Love my FLHRSI. Check the cam chain tensioners and think about the hydraulic tensioner upgrade or gear drive.
Old Feb 13, 2011 | 01:42 AM
BenRK05's Avatar
BenRK05
Why, whats wrong with cam on the RK's? I just picked up a 05 custom with 30,000 miles. When should I start worrying about the cam? How much does a hydraulic tensioner upgrade or gear drive cost? Thanks,Ben
Old Feb 13, 2011 | 04:31 AM
BadPiggy's Avatar
BadPiggy
He didn't say anything about cams going bad.
He said cam chain tensioners.
In the old setup, they tend to let go in the 30,000 mile range.
You could put fresh tensioners in for around $350.
Upgrade to the newer hydraulic setup for around $850.
Go with gear drives, that is, IFFFF your pinion runout is within spec, for around $1300.
The hydraulic setup is the better of the 3 options, in my opinion.
Whichever route you take, it would be wise to install new lifters, too.
You're already in there.
Cost is around $110 for HD brand.
Before you go dropping off your bike at some shop, get estimates and know exactly what work will be done.
Then come back here and post it.
Chances are they'll be selling you some **** you don't need.
You can get a straight answer here on the forum.
Old Feb 13, 2011 | 04:36 AM
HarleypsychRN's Avatar
HarleypsychRN
Typically carbs have a choke **** you pull out on the left side (just forward of the horn). In fuel injection models, they'll be no choke ****... if you look on the speedo and a little yellow light comes on then goes off like 2 seconds later...it means that that it's fuel injected. Easiest answer I can give you.
Old Feb 13, 2011 | 07:02 AM
04 rkcrr's Avatar
04 rkcrr
I've got an 04 Rk custom carbed with 29,000 on her. Just put new cams, lifters inner bearings and tensioners. My old tensioners had hardly any whare. I was very surprised after reading all these horror stories. The way they looked , The tensioners could have went another 129,000 miles. I still replaced them.
Old Feb 13, 2011 | 07:26 AM
Funnygirl's Avatar
Funnygirl
I have an '04 RKC with 32,000 on it. I had the cam chain tensioners checked a few months ago before the extended warranty ran out & they were fine.
So it doesn't always happen at 30K...
Old Feb 13, 2011 | 09:47 PM
BenRK05's Avatar
BenRK05
Ok ill wait till 40,000 miles to change them out. As much as i ride that should be in a couple of years. That will give me some time to do some research. I most likely do an upgrade to get more power out of the bike. It does not look to had to change out the cam and tensioners. Ben
