TW-555 Dyno Sheet
Old Feb 7, 2011 | 09:19 PM
Pc PaiN's Avatar
Pc PaiN
Default TW-555 Dyno Sheet
2010 FLTRX with D&D Fatcat, SEST, HF AC, and the TW-555
My tune still isn't straight and we want to smooth the A/F line out more before trying to move it to 13 to see what it does to the numbers. They aren't as impressive as some folks dyno sheets with this cam but I am super happy with the performance.
Old Feb 8, 2011 | 09:34 AM
robvg's Avatar
robvg
I have a set of the 555's on order and will post chart when installed.
Old Feb 8, 2011 | 10:22 AM
equandt's Avatar
equandt
It looks like you gained 17 hp and 11 tq. I'd be pretty happy with that.
Congrats!
Old Feb 8, 2011 | 12:41 PM
harleytuner's Avatar
harleytuner
Why is the sheet from July 2006? It shows you the speed not the RPM's too. Lines look nice and smooth though, get that A/F straightened out and you'll be O.K.
Old Feb 8, 2011 | 02:25 PM
Pc PaiN's Avatar
Pc PaiN
The computer in our dyno room has a bad battery so it won't hold the date when turned off. And the MPH thing is my fault. None of the tuners were there but I wanted a dyno print out so I started messing with it not knowing wtf I was doing
Def want to try dropping the AF to 13 since it seems to be what most people are running on this cam.
Old Feb 8, 2011 | 04:37 PM
harleytuner
If you click on the MPH at the bottom of the graph in WinPep you will get options, click on engine speed and it will change the graph to show RPM. Your bike should have been tuned to 13.1:1 for wide open throttle. Actualy it should have been tuned to it throughout the whole RPM range then after it was tuned the tuner should have set the AFR tables where he wanted in the MAP load.
Old Feb 8, 2011 | 04:48 PM
Pc PaiN's Avatar
Pc PaiN
We've been messing with the tune when we have time. My buddy is doing it for me so we just goto the shop on our days off and tinker with it for alittle bit. The bike wouldn't idle or take off from a stop without serious throttling when we started.
Old Feb 8, 2011 | 05:16 PM
harleytuner
That's cool. It's very gratifying when you can do the work yourself. Feel free to shoot me a PM if I can help in anyway.
Old Feb 9, 2011 | 12:56 PM
geargrinder's Avatar
geargrinder
Quote, "They aren't as impressive as some folks dyno sheets with this cam but I am super happy with the performance"
Your dyno tuner deserves credit for using the more conservative and accurate SAE correction and #5 smoothing rather then some who just provide impressive numbers.
Old Feb 9, 2011 | 02:57 PM
harleytuner
The tuners doing allright. IMO he should be targeting 13.0 on the A/F though, he's too lean for wide open throttle. He'd pick up some performance if he richened it up again.
