??BELT ISSUE WITH NEW SPROKET help???
Old Feb 14, 2011 | 11:15 AM
MOTOKILLER's Avatar
MOTOKILLER
Default ??BELT ISSUE WITH NEW SPROKET help???
So I just put a new sprocket on my buddies 07 roadking. the sprocket is 4 teeth larger. when i tried to put the tire back on, i cant get the axel in cause the belt wont strech anymore. Do i need to get a bigger belt since the sprocket is now bigger?? thx
Old Feb 14, 2011 | 11:40 AM
Mntsnow's Avatar
Mntsnow
Yes you need a longer belt.
Old Feb 15, 2011 | 07:47 AM
rare100thHD's Avatar
rare100thHD
Yes you will need a new belt for that large of a sprocket, I just did a 2 tooth larger on my 08 and love it. No belt change needed, the axle and belt went on easy, but the axle adjusting cams didn't go up as far as they used to. About 3/8 of a inch less. But it works fine. They just look like their sorta pointing down now. The Sportster 68tooth is the way to go so you will not have to change his belt, cause thats a lot of labor and money.
RoadKingCaptain
Jan 15, 2015 06:36 PM
bgtexas
Sep 10, 2013 10:56 PM
MOTOKILLER
Feb 14, 2011 12:02 PM
FAFHD
Nov 11, 2009 09:46 PM
clayman
Oct 15, 2006 03:08 PM
