Amsoil Filter Wrench
Old Feb 15, 2011 | 03:05 PM
HD160's Avatar
HD160
Default Amsoil Filter Wrench
I have an 09 Street Glide, could someone please advise me the correct part number for which Amsoil filter wrench to use in removing the Amsoil filter?
Thanks
Old Feb 15, 2011 | 03:13 PM
nvsteve's Avatar
nvsteve
G2309 was the part # a couple years ago when I got mine.
Old Feb 15, 2011 | 03:14 PM
KCFLHRC's Avatar
KCFLHRC
G2685
Old Feb 15, 2011 | 04:43 PM
HD160's Avatar
HD160
What year is your bike NVSteve?
Old Feb 15, 2011 | 05:30 PM
mkguitar's Avatar
mkguitar
if you are having a problem, you might want to consider using a phillips screwdriver to punch holes in the end of the filter. 1 top, 1 bottom
you line the area under the filter with aluminum foil, creating a channel to your oil pan.
once the filter is drained, just punch a hole in the side of the filter and use the punch/ screwdriver to turn the filter off.
nasty approach, but solves the oil on motor problem and the cost is minimal.
mike
Old Feb 15, 2011 | 07:29 PM
nvsteve's Avatar
nvsteve
07 Ultra. Filter is EAOM134CEA
Old Feb 15, 2011 | 07:58 PM
Tanker2's Avatar
Tanker2
Default gm filter wrench
It takes the same wrench as a gm AC filter. I'm talking about the cup shaped hex type. I use Amsoil filters and had a AC filter wrench and it fit.
13RoadKing
Engine Mechanical Topics
17
Feb 18, 2017 09:05 AM
TUCCI
Sep 26, 2016 08:53 PM
IzZy63
Apr 22, 2013 12:14 PM
Sharpie
Apr 2, 2013 11:20 PM
BlazingC5
Oil Archive (no new posts)
Jun 15, 2012 10:30 PM
