Oil problem
Old Feb 20, 2011 | 03:05 PM
Harley2534's Avatar
Harley2534
Default Oil problem
Just did an oil change on my 2008 RKC. But now when I refill it it shows that when I put just 3 quarts in that it is over full. It has been lowered in the back 1.5 but that is it. What is up with that?
Old Feb 20, 2011 | 03:19 PM
xxxflhrci's Avatar
xxxflhrci
How much time passed after running the bike an checking it? It takes a little bit for the filter to get saturated. That throws the level off a bit, but not 1 quart.
Old Feb 20, 2011 | 03:26 PM
Bill03E's Avatar
Bill03E
Silly question, but are you on the jiffy stand, or on some sort of lift with the bike level?
Old Feb 20, 2011 | 03:33 PM
dbell66253's Avatar
dbell66253
Two dumb questions:
1. You did change the filter right?
2. Is the bike on level ground on the jiffy stand?
Old Feb 20, 2011 | 09:05 PM
Harley2534's Avatar
Harley2534
Its the right filter and on the side stand. Just like it should be.
Old Feb 20, 2011 | 09:54 PM
03dragonRK's Avatar
03dragonRK
A lowered bike with a stock side stand will stand the bike more upright. Place a 2x4 flat side down under the rear tire to bring it back to stock. And check the level again.
Old Feb 20, 2011 | 10:04 PM
Ricky06Roadking's Avatar
Ricky06Roadking
My RKC has the 12" profiles on it. I just changed my oil, added 3.5 qts and after 3 minutes of run time it showed low. I added the other 1/2 qt of oil and it read full.
Highgrade
Mar 12, 2016 09:53 AM
fatboy1729
Jun 20, 2014 09:56 AM
fortyeight_408
Mar 10, 2013 10:32 AM
philo111
Sep 12, 2010 12:41 PM
michaelbarry
May 31, 2007 05:19 PM
