Audio Question
Fairing: http://recklessmotorcycles.com/index...uct_detail&p=8 I'm running the 4x5" speaker model
Head Unit: Fusion MS-IP500
Here's the manual http://www.jgtech.com/pdf/MS-CD500_M..._manual_V5.pdf
Speakers: http://dcgold.com/products/classic-line/n4c/ I'm only running two
I'm looking at adding these to give me more bass WITHOUT adding and amp: https://www.madisound.com/store/prod...oducts_id=8599
I'm also looking to do this on the super cheap, hence not adding the amp and better speakers. I plan on adding the woofers (cheap speakers) to Zone 2. The output on the HU is 70w per channel. Through the HU I can link Zones 1 and 2 together for volume control. I can also adjust max volume per zone as well as HPF an LPF frequencies.
My plan is to dedicate Zone 2 to the 5" woofers and adjust Max Volume, HPF and LPF accordingly to give me a bit more bass.
Finally my question, does this sound like it would work?
that is not a great spec, if you can find speakers with better sensitivity ( more than 90db @ 1watt/ 1 meter), you get more sound from the same amount of electrical power from your amp- before than amp starts to distort- and that distortion can blow speakers as a stressed amp "square waves".
I would suggest that you get to a place with a large spkr display ( like frys).
dial up some music on a head unit- take a cd you are familiar with maybe- set the tone controls at flat.
and switch from spkr set to spkr set, looking for the speakers which sound most natural and produce the most sound ( again you don't alter the tone or volume controls on the head unit).
Once you have it narrowed down you can then use the tone controls to see if screachy treble can be tamed down ( some have a resonant treble peak which cannot be tuned out) or if the bass holds together or "flubs" out when the bass control is boosted.
try the spkr candidates through different head units- in case you tester is adding distortion when you turn up the bass
( bass frequencies require about 10 X the electrical power as treble frequencies- that is why bass spkrs often have dedicated amps in many situations)
I think the polks I ended up with on my last bike were close to 98 db @1/1.
If the speakers are not weatherproof, consider that papercone type speakers can be scotch- guarded.
and - in all situations confirm that your speakers are in-phase, that means with the pulse of a bass drum the speakers should both move in the same direction at the same time.
If they are out of phase, as 1 speaker pushes a sound wave forward, the other pushes the same sound wave back- and the 2 speakers cancel each other out---this effect is most apparent with low frequencies
( there are testers which do this job, but you can pretty much tell by putting your hands in front of the speakers or lightly touching the cones, feeling that the bass pulses are in sync)
vendor- as much as I hate overspending for stuff on my bikes- some of the motorcycle specialists do have proven product and results, and that is worth something
and then there are expectations- what are you hoping to hear---is this while parked by the beach, or on the interstate with the helmet on your head.
and - hearing loss. getting the music over road and pipe noise may just blow your ears out. long trips i use ear buds, keep the noise out and keep the music in- lower overall noise fatigue.
mike
http://www.youtube.com/watch?v=ajp2o5OXr8U
