Jiffy stand question
Old Oct 11, 2006 | 01:24 PM
larry5h's Avatar
larry5h
Default RE: Jiffy stand question
I'll just keep using a short piece of 2x4.
Old Oct 11, 2006 | 08:16 PM
dchoran's Avatar
dchoran
gunrunner Date 10/10/2006 11:51:00 AM
There is no extension for the stand as to making it stand different from harley. The jiffy stand extension is simply a longer tab so it is easier to get your toe on it to put it down. Here is how the discribe it;
Jiffy Stand Extension Kit
This kit has been redesigned to add convenience and style to our existing jiffy stand. Polished and chrome-plated, it installs easily and includes all chrome hardware.
That extension is AWESOME - so much quicker/easier - you gotta get one.
Old Oct 21, 2007 | 04:03 PM
Harley.Driver's Avatar
Harley.Driver
Hello, i want to buy the extension kit from HD: 50233-00
Is it easy to install ? drill hole? someone have the "installation instructions" please?
Old Oct 21, 2007 | 07:08 PM
jpmflying's Avatar
jpmflying
I installed the extension and it took about 15 minutes. Have asharp drill bit. Drill a smaller pilot hole first. Thejiffy stand steel isvery hardas it should be.
Old Oct 21, 2007 | 07:30 PM
Big L's Avatar
Big L
ORIGINAL: larry5h
Ditto!
Old Oct 21, 2007 | 07:44 PM
HarlyFan's Avatar
HarlyFan
The Extension would be handy to have I just dont like the looks of it when it is up.......
Old Oct 21, 2007 | 09:09 PM
glens's Avatar
glens
I don't remember if it was this forum in particular or one of the others here, but a guy recently put an extension on his stand and started to get a mysterious clank when going over bumps in the road. I don't recall if he ever followed up (don't you hate that?) but we figured it was probably the jiffy stand dropping down against the now-not-quite-strong-enough spring, then rebounding.
Point is, if you put extra weight on the end of the stand it might not stay as tight in its upward position without addressing the spring tension.
Old Oct 21, 2007 | 09:14 PM
MNPGRider's Avatar
MNPGRider
ORIGINAL: sleepneagle
The lean is there for a purpose. with your bike on the jiffy and wheel in lock position. stand on the right side floor board. The bike does not come over on you. if you use a stand that lets the bike be more verticle, standing on right side floor board will allow the bike to come over.
Can't say I believed that....so, just back in from the garage, I'm now a believer.
Old Oct 21, 2007 | 10:58 PM
Beemervet's Avatar
Beemervet
It's a KICK stand. HAHAHAHAHAHAHA
Old Oct 21, 2007 | 11:21 PM
SIM's Avatar
SIM
ORIGINAL: MNPGRider
Yep, wife always boards from the right side while I am on the stand. It is so much easier and safer.
