08 FLHX passing lamp wiring help.
Old Feb 26, 2011 | 04:53 PM
kjkustoms's Avatar
kjkustoms
Question 08 FLHX passing lamp wiring help.
I purchased a complete set of passing lamps and mounts for my 08 FLHX. I am in the middle of the install and am stumped! Does the single gray wire coming from the lamp wire directly into turn signal connector? On the turn signal connector block on the turn signal side there is an open spot for the wire and on the inner fairing side there is a gray wire in the connector that is not used. Can some one confirm that this is where the passing lamp gets its power from?
sycle1
May 13, 2017 06:35 AM
FBLGODRO
May 12, 2015 01:57 PM
Housegoat
Jul 30, 2012 02:19 PM
84ironhead
Jul 29, 2010 09:59 AM
Fearlessleader
Oct 6, 2007 11:50 AM
