MP3 Question
Old Oct 16, 2006 | 03:05 PM
yota's Avatar
yota
Default MP3 Question
Any ideas if you can use any MP3 player with an 05 ULTRA. As long as it has the headphone jack it should work..Correct..Or is there some issues a person should be aware of.
Old Oct 16, 2006 | 03:16 PM
liltrk's Avatar
liltrk
Default RE: MP3 Question
Any one should work. There are people on here who use iPods, Irivers etc. with no problems.
Old Oct 16, 2006 | 03:29 PM
dchoran's Avatar
dchoran
Careful - if you get the HD OEM Roadtech one like I did for my 05 Ultra - it only reads up to a ~ 555 meg SD card ~ 120 songs.
In other words, you'll end up having multiple cards. Get something else!!!
Old Oct 16, 2006 | 03:48 PM
liltrk's Avatar
liltrk
ORIGINAL: dchoran
If you reformat the card and use WMA format for the songs, you can get about 300. I have about 325 on a 1Gb card.
Old Oct 16, 2006 | 04:18 PM
gman's Avatar
gman
can't you buy a bigger card (say a 1 GB) and use on the HD MP3 player? or is there something in the player that prevents using a larger capacity card?
Old Oct 16, 2006 | 04:28 PM
liltrk's Avatar
liltrk
1 Gb is the biggest one I have tried. I have enough songs on it, so I haven't gone bigger.
The player does have some issues with even the 1Gb card, though. eg. when you shut off the bike and start it again it is supposed to continue on the same song. Mine will do that up to about song 180 or so. After that it reverts to a lower numbered song. My cure is to poke random mode, then hit <next> until I get a high number, then shut off random mode. If I am riding for a couple hours at a stretch, it really isn't a problem.
Old Oct 16, 2006 | 08:12 PM
dchoran's Avatar
dchoran
Default RE: MP3 Question + HD MP3 PLAYER
I bought a 2 gig SD card this past weekend planning to double my song inventory on two wheels.
But I could not fit anymore MP3's on the 2 gig versus the 1 gig SD card. And I tried numerous SD readers/writers - NO GO.
It will max out at about 600 meg of MP3's no matter what.
Problem as I understand it - the FAT file system limits the # of or size of files in the root directory.
And the HD MP3 player doesn't allow subdirectories and can't read FAT32 or NTFS so you are basically screwed.
ALL my songs (thousands of them) are MP3's. Don't want to hassle with converting to .wma's. Rather have multiple SD cards.
I find it hard to believe that this Roadtech unit is sophisticated enough to be able to handle another type of format - are we talking the same unit???
If I had to do it again, I'd look for something different - probably would get a new CD/radio that could handle MP3's.
This EXPENSIVE sucker only lists the song number - no info, no skipping ahead, no grouping, etc..... VERY ARCANE!!!! PRE-HISTORIC. VINTAGE 1999.
Just trying to give advice to fellow forum members - DON'T BUY IT!!!! You'll be sorry - eventually.
paid4c4
Touring Parts
Apr 8, 2018 02:53 PM
RWTDCT
Touring Parts
Apr 24, 2017 09:13 AM
RWTDCT
Jan 12, 2017 02:27 PM
Harleynole
Nov 15, 2006 01:02 PM
dchoran
Nov 12, 2006 09:41 PM
