Installing SE compensator kit w/pics
Old Mar 27, 2011 | 11:43 AM
  #41
FXSTS-88's Avatar
FXSTS-88
Hey. Thanks for the how-to write up w/pix!!
A task I wasn't looking forward to. Now it seems easy enough.
Old Mar 27, 2011 | 11:45 AM
  #42
Ridewva's Avatar
Ridewva
Thumbs up
Bowa18, thank you for taking the time to post this. Nicely done with clear instructions and great pictures. I'm about to order a SE compensator and am installing it myself so this has been very helpful.
Old Mar 27, 2011 | 11:47 AM
  #43
swervin irv's Avatar
swervin irv
Great write up and pics.Thanks
Old Mar 27, 2011 | 11:53 AM
  #44
bowa18's Avatar
bowa18
Originally Posted by Ronp42
You mention Formula 1 at the end of your writeup, is that what you ran in your primary the entire time? The reason I'm asking, You said everything looked good. No visible wear! I see a lot of post on here where guy's are using ATF in their primary's. I'm wondering is ATF heavy enough to protect the Comp area with the pressure that's generated.
Yep, HD Formula + since new. No noticeable wear on anything in the primary. It's a good product and no reason to over analyze about using something different like some of us do. Very happy with what I saw and will continue using Formula +.
Old Mar 27, 2011 | 12:09 PM
  #45
Keithhu's Avatar
Keithhu
Question about grinding - I'm pretty sure there's a rotor puller tool that would allow you to just pop it out - no grinding necessary - ?
Old Mar 27, 2011 | 12:17 PM
  #46
Ridewva's Avatar
Ridewva
But there's not enough clearance to come out, whether you use a puller or not.
Old Mar 27, 2011 | 12:25 PM
  #47
Keithhu's Avatar
Keithhu
Wow, you learn something new every day. None of the youtube vids mention this - not saying it isnt so, maybe its a function of the newer cases?
http://www.youtube.com/watch?v=w8yF423yz5I
Old Mar 27, 2011 | 12:33 PM
  #48
HDV-GLIDE's Avatar
HDV-GLIDE
Not sure what year or model they were working on but it's not an '09 or later touring bike.....
  #49
bowa18's Avatar
bowa18
The tool just let you get a better hold on the rotor to break free from the magnetic bond it has with the stator. The lip on the case doesn't allow enough clearance to get the rotor pass it once you get it away from the stator. Grind, loosen up the inner primary (with the risk of leakage after you're done) or pull the inner primary are your three options. The grinding method is so damn simple to do it's a no brainer to me. I didn't come up with this idea, many have done it before me, I just wanted to try to provide some clear pics of the process. Thought about doing a video but I only have two hands and the wife didn't want to play movie maker with me.
Old Mar 27, 2011 | 01:00 PM
  #50
garand's Avatar
garand
This bike in this vid is a pre 2007 and doesn't have the lip on the inner primary cover. It's also about half the thickness of the new covers that have the lip. Even after grinding the lip you're still double the thickness of the pre-07 inner primary covers....if you are concerned about structural stability.
