Did I get a bad tire???
Old Mar 28, 2011 | 05:28 AM
Mendota Kid's Avatar
Mendota Kid
I've got 11k on my 2010 FLHTCU and both tires are still going strong...I agree with onedownandfiveup...2nd & 3rd gear are harder on the tire wear even on moderate acceleration...definitely need to get back to the dealer under warranty...bad tire for sure.
Old Mar 28, 2011 | 05:41 AM
rocstar50's Avatar
rocstar50
I just changed mine last week after 19,000 Km. I could have got more from the rear one but decided to change both together.
Old Mar 28, 2011 | 05:46 AM
Noble Jim's Avatar
Noble Jim
I usually get around 9K on my UC and RKC.
Old Mar 28, 2011 | 07:02 AM
nhbiker1961's Avatar
nhbiker1961
I usually get around 11k on my rear tire and 20k on the front.
Old Mar 28, 2011 | 07:36 AM
piasspj's Avatar
piasspj
Lots of factors including tire pressure, weight on the bike and the types of roads you ride. Gravel eats tires, improper pressure creates uneven wear.
Normal wear for most bikes is around 10-12k from a rear tire, 20-25k for a front.
Old Mar 28, 2011 | 08:48 AM
cltgt's Avatar
cltgt
Originally Posted by tpmurray
To the OP - It would help to know the year - '09s and up are different tires utilizing a compound design. The center of the tire on the newer bikes has a harder rubber compound.
I have an '08 and change way before the wear bars appear and get 13k - 14k easy.
As sig says, 2010 Street Glide. Purchased bike Christmas Eve from dealer with brand new tires that had zero miles on them.
I never use rear brake only for stopping
I check pressure before I ride and also had it checked as well as the rear suspension Saturday and it was at recommended pressure. I have not had a passenger on this bike yet as I want to be 100% familiar with it before putting someone else's life in my hands...
The one thing I can assure is I don't hot rod this bike. I haven't even had the rpm's over 3700 as there is no need. If I want to go fast, I have other toys for that..
I did purchase the wheel/tire protection package, so I will have the dealer check it out.
Old Mar 28, 2011 | 09:08 AM
leicafish's Avatar
leicafish
Just wondering what type of fuel milage do you get and what shape are your rear brake pads in.
Old Mar 28, 2011 | 09:20 AM
angelrod's Avatar
angelrod
Right tire pressure also help tires to last longer ,but 3000 is an acceptable
Old Mar 28, 2011 | 09:27 AM
cltgt's Avatar
cltgt
Usually around 42mpg. Haven't taken any long trips. We tend to run to the horse farm and beach often. About 45 miles each way to Port Orange/ Daytona Beach. Brake pads were replaced when bike was traded in. I'll have to pull them and see if that is the case or not. I know the oil could not have been changed. If it was, then this engine won't be lasting a long time as it was jet black and thick when I drained it.
Old Mar 28, 2011 | 10:23 AM
glide2meetu's Avatar
glide2meetu
front or rear?
