Elite 3 tire dilemma
Old Mar 29, 2011 | 04:58 AM
GAZRNR's Avatar
GAZRNR
I have 21,000 on my front E3 and will replace it at 25,000, I probally could get more but have a new E3 now sitting in my garage. My rear E3 only has about 9,000 but still looks great & should easily last the whole season unless road debris gets it. I am running 40 PSI rear and 38 PSI front on my 98 RK.
Old Mar 29, 2011 | 09:39 AM
iclick's Avatar
iclick
Originally Posted by smithbrl
Bob, I remember you said you installed taller rear shocks. I don't know much about how it would effect front tire mileage, but I have a lowered front end and standard height rear and was wondering if it could cause things like this to happen.
A higher rear end may shift weight to the front and give you poorer tire mileage. If this is true there would be less weight on the rear and give you better tire mileage on the rear.
Hi, Cecil. Never thought about that, and I have indeed gone up to 13ź" on the rear, but that's only ź" higher than a standard EG. I can't see how that would affect tire life more than a minute amount, but it's definitely worth discussing. It would seem that it would make the bike more prone to dive, but I haven't noticed any such behavior out of the ordinary, and in fact I have less dive than before since I've installed SE Heavy fluid in my front forks. I can't see the fluid being a factor either.
I think I'll order another E3 front, but this one I'll keep at 40# like the rear, and will probably pump the rear up to 42# cold. I'm going to wait a bit, though, just in case more good ideas come from this thread.
Old Mar 29, 2011 | 10:09 AM
rustynuts's Avatar
rustynuts
iclick, what size E3 are you running on the rear of your 07 SG?
My 07 Road King specifies a rear tire size of MU85HB-16. When looking at Dunlop E3s, all I see is the MU90HB-16. The Dunlop 402 is available in the MU85HB-16.
Old Mar 29, 2011 | 02:12 PM
spratman's Avatar
spratman
E3's are the only thing I've ever used on my GW. Still have them on. My RKC came with D402's. I changed the rear tire to a Metzler 880 and caught a piece of metal dead center in the middle of the tire. DAMN! Back to Dunlops.
I'm glad they still seem to work great on the HD's. I always like the tires.
Old Mar 29, 2011 | 03:32 PM
dgretz's Avatar
dgretz
Originally Posted by Corndog
Is there a wide whitewall E3 for my 2007 RKC?
I have not seen any E3 whitewalls from Dunlop I do not think they exist
Old Mar 29, 2011 | 03:59 PM
iclick's Avatar
iclick
That's correct.
Old Mar 29, 2011 | 04:06 PM
iclick's Avatar
iclick
I think I'm going to stay with the E3 for my next front tire. I've decided that my mileage issues may be at least partially tied to prioritizing the front brakes and using both front and rear only for hard stops. Also, I'll probably bump the pressure up to 40 psi cold for the front and go to 42 psi rear.
Old Mar 29, 2011 | 04:08 PM
gunner11's Avatar
gunner11
I'll stick with Avon Venoms, 10k and still got 6/32 on both. Can't beat the ride for smoothness and cornering. JMO, besides I keep good rubber on no matter what milege, that's not my main concern is how many miles I get out of a tire.
Old Mar 29, 2011 | 04:18 PM
TORQUEY's Avatar
TORQUEY
Originally Posted by iclick
I'm one of the most enthusiastic cheerleaders for the Elite 3 tire for older bikes ('08 and earlier), but I now have one concern. Whereas my rear tires have been wearing very well indeed, 20k on my first and my second wearing at the same rate, the first E3 front is shot at only 18k miles. WTF? I always got 25-35k out of D402's, but 18k is not acceptable. I've always kept pressure at 37# cold on the front, 40# on the rear. Who would've thought a rear tire of the same model would outlast a front on a Harley!? It just doesn't make sense.
I'm now wondering if I shouldn't replace the E3 front with a D402, which is something I thought I would never do. OTOH I don't like the groove tracking of the D402 and it's almost worth the lower mileage to be without it with an E3. I'm not sure what I'm going to do yet, but I may go back to the E3 rear, D402 front arrangement I ran before the present pairing.
Anyone else run into this dilemma?
Check the tire pressures again. I assume from the mileage figures you're getting that you're running helium at 100 p.s.i....
Old Mar 29, 2011 | 04:41 PM
iclick's Avatar
iclick
I've used only the MU90-16 and it fits perfect. It's .01" taller and .06" wider than the stock MU85-16's.
