ecm code help
Old Apr 2, 2011 | 10:32 AM
bambamblazer's Avatar
bambamblazer
Default ecm code help
I had a code on my bike so i pulled it and cant figure out why i had this code???
P0261 Front Injector Open/Low EFI
04 ultra stock except an big sucker , true duals and a power comander
Old Apr 2, 2011 | 11:11 AM
fireaxxe's Avatar
fireaxxe
Is it a current code or historic code, do have a drive-ability issue. This could be one of a few things, you wiring to the injector could be faulty this will cause a low voltage issue. The plug may not be plugged into the injector or a broken wire causing an Open circuit condition, this same open circuit could be a bad injector. Check your wires first then swap the injectors and see if the problem moves with the injector to the rear.
KiveKur
Electrical/Lighting/Alarm
Aug 20, 2014 06:12 PM
jomohog
Apr 9, 2012 09:25 AM
lh4x4
Nov 2, 2011 09:35 PM
nkauf21
Aug 15, 2010 04:08 PM
