Power Commander / Starter bang
Old Apr 9, 2011 | 12:46 PM
frozensoul's Avatar
frozensoul
power commander on my 09 sg and i dont notice any bang from startereither way. only time starter ever banged was once in the winter before i put tender on battery when it got low.
Old Apr 9, 2011 | 12:57 PM
bronxbill's Avatar
bronxbill
I've got a PCV and have never had a bang no matter how long I wait before hitting the start button
Old Apr 9, 2011 | 05:59 PM
Neckball's Avatar
Neckball
I had this problem on my Deuce when the battery was going bad
Same for me. New battery, no more bang.
Old Apr 9, 2011 | 07:51 PM
user 8373900's Avatar
user 8373900
Originally Posted by wideopen1967
Can someone help me understand why when I start my bike, if I don't hit the starter switch in less than 3 seconds after I turn the power on I get the dreaded "starter bang"
I have heard that this is a Power Commander issue. And it has gotten worse since I installed the PC.
Is there anything in the mapping that can make this better?
What happens with the PCIII is, if you wait too long it goes into a diagnostic mode and turns over like 3 times before it starts..The bang you hear is the compensator bottoming out. Unrelated.. However when the PCIII delays the start the compensator is allowed to travel to the end of it's available travel and bottom out causing the bang you hear.
Old Apr 9, 2011 | 07:52 PM
user 8373900
Your 2011 has the new compensator..No bang.
Old Apr 9, 2011 | 07:59 PM
lp's Avatar
lp
Close. The "Delay" is caused because the PCIII actually turns OFF after the fuel circuit primes and when you hit the starter the PC turns back on (power is returned) where it initializes and after about two-three revolutions of the engine, it finally starts.
The PCV does nearly the same thing although it remains powered on but still re-initializes after you hit the starter button. The delay before startup is not as long though. In either case (PCIII/PCV) if you hit the starter button right after you turn the bike on and while the fuel circuit is priming, it will start up "quick".
Like you've said, the "Bang" has nothing to do with PCV, its the comp...
lp
Old Apr 9, 2011 | 10:53 PM
mcain49's Avatar
mcain49
Ditto - The PCV doesn't ever bang on my 10 UC no matter how long I wait.
Old Apr 9, 2011 | 11:10 PM
iclick's Avatar
iclick
This is the correct answer. If you want to eliminate the clunk, replace the stock comp with an SE upgrade.
Old Apr 10, 2011 | 12:06 AM
sportyrider1's Avatar
sportyrider1
Had the same problem went to a couple of dealerships before I found 1 that didn't say it was normal replaced Stock Comp. with a SE comp, problem solved. When you go to the dealer first ask if they have been having any trouble with the Comp. on your year then complain about the bang and if they agree to look into it request a new style comp (SE) if it needs replacing.
Old Apr 10, 2011 | 01:59 AM
legendzzz's Avatar
legendzzz
It is the Compensator most likely, mine did the same and when I replaced it( on my 2010 Ultra ) with the SE it was quiet and ran smoother?
Tell the dealer to listen and he will tell you the same, just make sure you have a Warrantee
