White Wall Cleaner
Old Apr 8, 2011 | 07:14 PM
SeeMeDo's Avatar
SeeMeDo
Man you can use all those chemicals if you want I did until I tried some Borax ya the old school Borax it beet anything else hands down. It's too easy all you have to do is mix up some soapy water use an old rag, get it wet dip it in the Borax and just rub down the white wall letting it dry after you do the whole tire, one beer or so rise it off and it's so white without any real effort. You don't have to worry about getting Borax on anything just spread the past on let it dry and rise it off. I use a stiff nylon brush to get the dried Borax off the tire in a few places but it's a no effort deal all around.
Old Apr 8, 2011 | 07:16 PM
ErikElvis's Avatar
ErikElvis
Definitely Bleach white and a hard bristle brush.
Old Apr 8, 2011 | 07:30 PM
gtrb's Avatar
gtrb
Active Streak: 120 Days
Spray on a lot of Westley's Bleach White and scrub with a stiff brass brush. It doesn't harm the white wall or the tire. The more often you do it, the easier it is.
Old Apr 8, 2011 | 07:31 PM
moondog99's Avatar
moondog99
Originally Posted by hockey8787
Bleach white from auto stores
+1 use it to clean the white lettered tires on my bike and does a great job with very little scrubbing.
Old Apr 8, 2011 | 07:39 PM
cdestuck's Avatar
cdestuck
As above, Wesleys Bleach White. been around for a ton of years, been in my garage for a ton of years
Old Apr 8, 2011 | 08:21 PM
Roadking Cal's Avatar
Roadking Cal
SOS pads! Works like a charm every time!
Old Apr 8, 2011 | 09:03 PM
FDHOG's Avatar
FDHOG
Make sure you rinse off your wheels after you use the Bleach White.
Old Apr 8, 2011 | 09:12 PM
T K Glider's Avatar
T K Glider
Get a rag put some gas on it,wipe just the whitewall and in less than a minute they are snow white.
T K
Old Apr 8, 2011 | 09:27 PM
shagnasty's Avatar
shagnasty
Mr. Clean magic eraser. Nothing works better and you don't have to spray those harsh chemicals all over your wheel/tire. Had a RKC for 5 years and did about everything mentioned above until I tried the magic eraser.
Old Apr 8, 2011 | 09:36 PM
born4bikn's Avatar
born4bikn
Turpentine ... put on a clean rag it cleans very well
