What can cause erratic tachometer?
Old Apr 10, 2011 | 04:05 PM
DTTJGlide's Avatar
DTTJGlide
Default What can cause erratic tachometer?
I was out for a ride today & tach started to jump around & give erratic reading, then got a check engine light so I figured I better head for home. Bike is a 2000 FLHTCUI, when I got home I checked the trouble codes & got a #35, tachometer. The second question is can it cause any other problems with the running of the bike? I can live with a bad tach until I can get it fixed, I just don't want to get stranded. TIA
Old Apr 10, 2011 | 05:42 PM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
Loose fitting, bad insulation on cable or the "dt's".
Old Apr 10, 2011 | 06:21 PM
reesestewww's Avatar
reesestewww
I do not know the answer to your question or sure. But, in other applications than HD this symptom is caused by a failing/failed voltage regulator.
Old Apr 10, 2011 | 07:34 PM
DTTJGlide's Avatar
DTTJGlide
Hoping maybe Dawg or somebody with some tech knowledge would see this.
Old Apr 10, 2011 | 08:10 PM
Beemervet's Avatar
Beemervet
bad ground
Old Apr 11, 2011 | 07:25 PM
DTTJGlide's Avatar
DTTJGlide
One more try.
Old Apr 11, 2011 | 08:43 PM
stu07hd's Avatar
stu07hd
Loose battery terminals?
giacomo56
Mar 7, 2016 09:21 AM
HarDlife
EVO
Jun 27, 2014 08:43 PM
MSFLH
Jun 7, 2011 10:04 PM
mtnlvr
Aug 1, 2010 10:48 AM
introuble
May 14, 2007 05:12 AM
