Frozen motor
Old Apr 18, 2011 | 10:14 PM
1931jamesw's Avatar
1931jamesw
Could the primary chain be broke?
Old Apr 18, 2011 | 10:22 PM
user 8373900's Avatar
user 8373900
If the starter is hitting the compensator you have serious problems...Just sayin'.
Hope all turns out well.
Old Apr 18, 2011 | 11:17 PM
ke5rbd's Avatar
ke5rbd
If it was dropped valve I think you would have loud noise. Probably something in the primary area. Did you try pushing it backwards to roll the motor. The compensator being loose can sound like valve train noise also. I have seen that happen. If you get it to free up you still have to find out what happened. I wouldn't attempt to start it until then. Good luck.
Old Apr 18, 2011 | 11:26 PM
j1mmy's Avatar
j1mmy
if push starting the bike twisted the crank,it would never stand up to an electric starter.. (less of)same forces in place..if it would roll backwards it sounds like a dropped valve.if not??sounds pretty bad ether way. hopefully it is just something loose and in the primary chain...a lot easier/cheaper to fix
Old Apr 19, 2011 | 05:38 AM
smokindave's Avatar
smokindave
Got a feeling the comp bolt came loose, wedging the comp and chain inside the primary. By the way, the starter turns on the clutch hub not the compensator. Let us know what is found.
Old Apr 19, 2011 | 07:36 AM
imrotton2's Avatar
imrotton2
how did the plugs look when you pulled um??(were the gaps closed or not like they were suposed to be)
Old Apr 19, 2011 | 07:39 AM
imrotton2's Avatar
imrotton2
mine dropped a valve last year,,, prior to it locking up, it sometimes sounded like the rev limiter kicking in way too soon
Old Apr 19, 2011 | 07:45 AM
Intensefab's Avatar
Intensefab
Dealer is draging there feet even looking at it. Was going to be heading home today, but at this point who knows.
Plugs looked fine, i hope it is just the primary. My warranty expires tomorrow and that would be covered. The service guy said if it is the motor and because i put cams in it it would not be covered.
Hopefuly have some news today!!!
Old Apr 19, 2011 | 08:05 AM
lp's Avatar
lp
They would have to prove it was the Cams that ruined the engine.
lp
Old Apr 19, 2011 | 09:42 AM
mtclassic's Avatar
mtclassic
lp
unfortuneately if the dealeris being a jerk thtat won't be hard to do unless they are epa approved cams installed by the dealer. I know it might be chicken sh*t but once non epa approved stuff goes in it is fair game for the moco to deny warranty. The car manufacturers are doing it for performance chips. My buddy had a tranny in his new dodge pickup go out and it was brand new and they denied it because he had chipped it. He tried to fight it and lost.
