I have gone round and round with this problem...the fork mounted deflectors help the most..I made several sets my self from aluminum, and then bought the Kuryakyn one for looks....The freedom wings help when they are turned out, so the scoop air in toward you instead of pushing it away...and the other big help is a clearview screen, with the vent..the vent makes a big difference....I can ride at 70 to 80 with no turbulence , no eyeglass shake , ball cap on no problem...........
Thats the difference.... put a helmet on and see what happens. Generally the bigger the helmet, the worse the turbulence.
Yes they will fit and Yes they help the air coming up and over the tank behind the fairing...
some cell phone pics
Do the fork deflectors cause any problems with engine heat during the summer? I keep my lowers on during the summer and open the vents, but the deflectors look as though they cover the vents.
I have a set of chrome fork mounted deflectors sitting in my basement if someone wants to buy them. They are not perfect as they were on my bike for several years and one of them has what appears to be a water stain on the chrome that I cannot wax out. If interested PM me and I can get some pictures taken and send them to you. Someone might as well put them to good use.
Hey can you email me? i will buy them off you. votts@live.com
sorry i dont know how to pm you or i might not have that privelege
As I said above, with the fork deflectors I'm pretty miserable above 60°F (though I wear full leathers all the time). Doesn't matter that I open the fairing lowers vents or tip the upper fairing air deflectors as much as possible (they interfere with the fork deflectors, so cannot be tipped fully open).
I think I'll have to remove the fork deflectors during hot weather months. So I can either have teeth-rattling turbulence or roast. Guess that's what I like about my Road King; I don't have either one. 'Course I also don't have the stereo or any weather protection.
cookiemech..... Did the fork mounted air deflectors completely solve the helmet buffeting / teeth chattering problem?
I am also currently trying to decide between the versatility of the RK and the fairing of the SG.... I like the benefits of the fairing but I don't want any teeth chattering.
i have the exact same setup as you but without the lowers. i have zero windblast coming into the riding area, it's diverted to about an inch above my helmet with the same shield you have on your bike, the 10" long ride shield with the flip at the top. i'm tall and the windstream goes above my head altogether. i also have the side adjustable wings at the outer edge of the fairing along with the fork air baffle which bolts onto the lower triple tree. same setup as you have but i don't have the lowers. those lowers is the only difference from what i read in your statement, but i've never heard of them causing wind to rattle your face or chin.
