cats out
Old Apr 26, 2011 | 09:57 AM
Dr.ultra2010's Avatar
Dr.ultra2010
Default cats out
hearing bad things about no cat in header...took mine out 2010 ultra103,se air,sert,4in rineharts then dyno..????did i screw up??
Old Apr 26, 2011 | 10:10 AM
Trojan63's Avatar
Trojan63
I have a 2010 FLHTC, took mine out, no problems....and sounds better to boot!!!!!!
Old Apr 26, 2011 | 10:28 AM
drukanfu's Avatar
drukanfu
You should be fine, if you feel something is wrong get it dynoed. Should be a little louder, 1 or 2 hp stronger and definately cooler by you leg. you might be running a little leaner. You should get your AFR a little richer than what the factory set it at. Get a PC 5. I don't know if the SERT can change that.
TheStinger
Touring Parts
Sep 16, 2011 04:49 PM
LionBaron
Road Trips
Aug 29, 2010 06:35 PM
rm4040
Mar 11, 2010 06:57 PM
