Need Help, Performance and Temp
Old Apr 30, 2011 | 07:39 PM
PappyUSMC's Avatar
PappyUSMC
Question Need Help, Performance and Temp
2009 HD Ultra Classic
50K, Only Owner
PC5(fuelmoto), Rinehart Slip-Ons, SE Stage 1 Air Cleaner, Parade Fan, and MUCH MORE
Well maintained. Synth since mile 4
Bike seems to be running MUCH hotter lately. So hot that the wife is barely able to use her foot pads after about an hour of semi city riding.
When I went to restart it today, it sounded like it had to really try to turn over for a split second then good to go.
Clock reset to 1200. Usually only loses a second at starts.
Bike is dropping ALL power when it starts, it use to only drop the radio some of the time.
Idle and running seems a bit rough.
I know this is all vague. I appreciate any comments and insight.
Mainly, I am looking at what I can do to cool my scoot a bit.
Thanks.
Pappy
GySgt USMC
Old Apr 30, 2011 | 08:03 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
loose battery terminals? or a short,would be my thoughts about the clock reset.
Old Apr 30, 2011 | 09:39 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Regardless as to the modifications, sounds way too lean & your getting heat soak when restarting. Common for the later models to have. Unless your Bike was tuned on a Dyno, you have a canned map and sometimes thats not good enough for a specific application. FuelMoto does a good job but nothing beats a real time dyno run & tune.
Electrical issues : Tighten all connections from the battery to the starter, sometimes the battery bolts need replacing, pull all fuses, clean contacts & reinstall, check starter ground & bolts holding it on. Might help....
Old May 1, 2011 | 05:16 PM
PappyUSMC's Avatar
PappyUSMC
Anyone else have any incite?
Thanks!
JoshR84
Jun 14, 2016 07:50 PM
roussfam
Jun 23, 2014 09:43 AM
Skippy97
Oct 6, 2013 04:57 PM
h964
Mar 16, 2013 04:02 PM
Rock Chalk
Jun 20, 2012 10:34 PM
