Oil temperature?
Old May 2, 2011 | 06:17 PM
'05Train's Avatar
'05Train
I've posted my used oil analysis here before. I ran around 5,500 miles on Amsoil 20W-50 in 3 weeks last summer with ambient temperatures between 90-105 degrees. There was no appreciable breakdown whatsoever.
Change your oil regularly and stop worrying.
Old May 2, 2011 | 06:24 PM
themensh's Avatar
themensh
"You know the truth, I know the truth, but until a big name says its so in a magazine ad, the masses will remain ignorant."
I have an article, from American Iron, that I clipped from May '08. The basics are, this guy has a 2000 Fatboy w/a 113" engine. Long rides, high speeds (85-90 MPH) hours at a time, has an oil cooler. Oil temp shows 240-250. How can "I get my temps cooler?"
American Iron asked.."Why do you want to lower the temps....those are right on the money. If you can ride that fast for that long and only get up to 250, be happy."
I think most of us are safe.
Chuck the mensh
Old May 2, 2011 | 07:42 PM
OnTheFence's Avatar
OnTheFence
So there are 3 known systems on how to read this retarded guage.
The Iclick theorum
The iwillfixthem4u method
The fabrik8r way
My 96" with no cooler ran straight up on the days in the mid high 90's. I guess I could call that 245.
Now with my 103 and cooler, I am seeing 1 or 2 hashes past the big hash where 180 is printed on the guage. I've been calling that 180 -190. When it hits the dot I call it 200. I haven't seen the 90's yet on this bike, but it do believe by what I have seen on the guage it is running 20 degrees cooler than my last bike with no cooler.
Whatever the real temp is, I did find that there was no relative difference between syns and dino oils on the guage.
Old May 2, 2011 | 10:10 PM
fabrik8r's Avatar
fabrik8r
Those are pretty impressive results, another testament to synthetic’s resilience to extreem conditions. So are you gradually extending your oil change intervals? If there is no appreciable breakdown at 5500 miles, why worry about changing it too soon? You didn't mention anything about the temps that oil experienced during its 5500 mile life.
Old May 2, 2011 | 10:20 PM
lh4x4's Avatar
lh4x4
fabrik8r - The better example is last year in August during the tropical heat wave the south was having with 100 to 105 temps. We were on or way to Key West we were caught in a traffic tie up in Tennesee and it took an hour to get around it. We moved a car length then stopped. This repeated itself as I said for one hour. The temp. was 100.
The bike was an 010 Utlra with oil cooler and stock exhaust with the cats in the head pipes. The bike did not over heat. The rear cylinder deactivation did not kick in. I am sure the the stage before deactivation did kick in which is the ECM increases the afr to the rear cylinder.
We recorded 100 degrees as the low and 105 as the high from the weather each night on TV at the motel.
I was running 89 octane and not 91. I am a cheap @ss.
The oldest son was on an air cooled BMW RT1200R. He did not have trouble but said that the BMW felt like it was close to having trouble.
My youngest son was on a 06 Street Bob with stock pipes and a Cobra Fi2000r fuel programmer which puts the afr to 12.1 to 1. The 06 Bob was the first year with the rear cylinder shut down and it too did not shut down.
It has been a while since the manual, but memory is that the heads need to exceed 370 degrees to shut down the rear cylinder. Below that HD is not worried about engine heat.
I have three bikes with TC96's. The 07 FXSTC, 010 Ultra and 010 Dyna SG.
I ride these bikes all over the country since I retired. I just have not had a single issue with heat from them. I'm 70 and you younger tougher "bikers" should be able to to it better than me.
The trip totaled a little over 4,000 miles.
The HD's were running Syn 3.
Old May 2, 2011 | 10:22 PM
fabrik8r's Avatar
fabrik8r
Chuck the mensh
Okey dokey, you don’t even really care about this topic, are you just bored, your little story is a real weak attempt to discredit my opinion. Kudos for trying to throw the magazine comment back in my face but you fell short. Do you really think your going to change my mind by quoting some article claiming that running 240-250 is right on the money. I’m pro-cooling, nothing you or anyone else here says will ever change my belief that cooling is a worthwhile endeavor. I’ve never seen anyone start an anti-cooling thread, just folks bashing those who start pro-cooling threads, if you’re not about it then stay out of it.
Old May 2, 2011 | 10:29 PM
babyray's Avatar
babyray
Originally Posted by pauletich
I am in AZ and have a 07 FLHX. I avg about 270 before the oil cooler and now about 240-250 in the summer time. My wrench said as long as its below 300 you shpould be ok.
Im no harley mech. but everything ive ever read says 300 is way too hot.
Old May 2, 2011 | 10:35 PM
FDHOG's Avatar
FDHOG
Fabrik8r...Lighten up. It's an air cooled motor. In cooler temps, they run cooler. In hotter temps they run hotter. Stop and go, the temps go through the roof.
Why do you think the MOCO put the EITMS system into effect. They know these babies run HOT.
Use a good synthetic, change at every 5K, and enjoy the ride.
My RKC has been tuned and runs great. I still hit temps of over 250 in stop and go. Nature of the Beast.
Old May 2, 2011 | 10:39 PM
fabrik8r's Avatar
fabrik8r
Ok, you went on a big ride last summer and the heat didn't bother you and your engine didn't blow up, and that is how you define didn't overheat. You older "Real Bikers" are way tougher than me, I'm a little soft so I'm gonna keep on cooling. Sorry you didn't convert me either.
Old May 2, 2011 | 10:59 PM
fabrik8r's Avatar
fabrik8r
I didn't start this thread. I don't know why everyone feels the need to assure me everything will be ok with this air cooled motor, don't worry, dont be concerned about the heat. I don't have temp problems, my bike runs cool as a cucumber, with a lean tune, and just like everybody else, I haven't had any problems either. I'm done with this thread.
