Wiring question
Old May 6, 2011 | 07:56 PM
cnnesseth's Avatar
cnnesseth
Default Wiring question
I have a 2010 street glide and I would like to put red neon strip lights under each saddle bags and have them work as brake light but also like to use as running light once in awhile. I need help on how to wire them to brake light but also be able to use as running lights through acc. switch. Is this possible?
Old May 6, 2011 | 08:00 PM
tidbit1's Avatar
tidbit1
I know this isn't answering your question but i have a Badlander run,turn, brake module and i added LED's on the saddle bags and put LED's in the OEM lights . The Badlander is compatible with the alarm system on my 09 SG.
Old May 6, 2011 | 08:34 PM
RANGER73's Avatar
RANGER73
Ya, it's possible. But it's the some times what to work as something else that's the complicated part. You could use a single pole double throw switch to change which feed (brake or running) powers the neons.
red hot SG
Jun 5, 2011 03:53 PM
TheFigment
Jun 4, 2011 01:36 AM
1slo6
Jul 20, 2009 11:37 PM
Wrongturn
May 13, 2009 01:20 AM
tsglide
Aug 28, 2006 02:31 AM
