Installing Back Off flasher on Street Glide
Old Jun 4, 2011 | 10:33 PM
red hot SG's Avatar
red hot SG
Stage III
Default Installing Back Off flasher on Street Glide
Instructions say to splice in to brake light wire between switch and light...I'm adding saddlebag lid spoiler lights that plug into the accessory plug...not sure if I need to splice in upstream of that accessory plug...maybe off the brakelight switch...any ideas would be helpfull
Old Jun 5, 2011 | 02:30 PM
rebbe18's Avatar
rebbe18
If you are plugging the lid lights into the accessory switch, then they will not function as brake lights. They will go on when the ignition is on and off when the ignition is off. They will function as running lights only.
In order to have them function as brake lights and/or back-off brake lights, the power must come from the brake light wire and the back-off module goes in between the brake light wire and the lights.
Old Jun 5, 2011 | 03:53 PM
red hot SG's Avatar
red hot SG
Stage III
The spoiler lisghts actualy plug into the accessory circuit connector under the seat which gives them RUN/BRAKE function...wondering if I have to go back upstream from that accessory plug...Thanks
Ranger12s
Shovelhead
Sep 30, 2017 08:27 PM
Mr.Softy
Jun 21, 2015 09:36 PM
qball1968
Aug 21, 2014 08:27 PM
coopaloop108
Nov 30, 2012 09:43 AM
red hot SG
Electrical/Lighting/Alarm
Jun 5, 2011 07:25 PM
