problems with lowered street glide front
Old May 10, 2011 | 08:32 PM
getnbizzy's Avatar
getnbizzy
Default problems with lowered street glide front
just joined the 21" font wheel club. was doing some measuring from factory to new wheel and the lift is about 1-9/16". I decided to go with the progressive spring kit and I can lower 1" or 2". I told my mechanic to go with the 2" springs. He said the tree will hit the fender and he knows a couple people that did it. He said I'd still have to be careful with the 1" springs too. The directions that came with the progressive kit say the total travel of the forks will not change.
I'm now thinking I need to find a new mechanic. Anyone have any suggestions or first hand experience with this one? Thanks.
Old May 10, 2011 | 09:37 PM
rg_dave's Avatar
rg_dave
Forget the mechanic and do it yourself. I dropped mine 1" with the progressive drop in kit. Its easy to do. Use the manual and there are several threads on it. You'll need a buddy to help you put the fork caps back on but thats it. Make the seal tool out of PVC pipe. Just do a search and you'll find everything you need here. I added ricor intiminators. I have never come close to hitting the fender.
Old May 11, 2011 | 01:24 AM
Billdoe's Avatar
Billdoe
another thing you may want to check is Inside of Back fender may rub the fender and at high speeds burn the Paint off fender. i went to a 21 on my 07 Electra glide and lowered it 2 inch to compensate for the lift the wheel gives the bike.. so my bike would be like using a 1 inch lowering kit on yours... i had my buddy do mine once i removed fork legs annd took to him. as for the fender, quick way to fix it if it may rub like mine did is to cut the bottom out of the Fender mounts so you can raise fender a tiny bit .. i learned the hard way and burned the paint on back of my fender .. im using a 21x3.50 60 spoke wheel running a 120-70-211 tire
Old May 11, 2011 | 12:33 PM
rg_dave's Avatar
rg_dave
This has nothing to do with the fork question but since it was mentioned in a previous post. Tape a 1/4 inch nut to the tire and spin it both directions. If it hits you need to tilt the fender. All you have to do is take a 3/8" (I think thats the size, it should be slightly larger that the fender mount hole) and ream the rear fender mount hole. The fender will tilt perfectly.
Old May 11, 2011 | 05:38 PM
getnbizzy's Avatar
getnbizzy
well it's too late because i already dropped it off at the mechanic yesterday. he talked me into lowering only 1" which i guess will be fine, but I'll still be about 9/16" higher in the front. I already put a reach seat on the bike since my inseam is only 30". That's why I though i'd be better lowering it 2".
Thanks for the replies. I don't seem to have clearance issues, but will definitely try the nut trick. I did read about drilling out the back holes to give room for adjustment.
Old May 11, 2011 | 05:40 PM
getnbizzy's Avatar
getnbizzy
someone told me if you are desperate for something to push the seals in, you can use the other half of the fork.
I have the exact same 09 red hot sunglo as you. well now its black and orange, but it was red when i bought it. i miss the red.
Old May 11, 2011 | 05:47 PM
dbell66253's Avatar
dbell66253
I have the progressive monotube 2" under and have absolutely no problems, the bike handles better and it doesn't have any clearance problems.
bikerlaw
Feb 26, 2014 09:38 PM
jay flex
Apr 2, 2013 10:27 PM
supercrewser
Nov 20, 2012 06:50 PM
markthecelt
Mar 2, 2008 09:56 PM
07blackcherryflhx
Nov 22, 2007 12:04 PM
