Riding Alone
Old May 12, 2011 | 07:30 AM
hullhorr's Avatar
hullhorr
I'm with most on this one. There is no magic spot it depends on the conditions your in, but I favor the left tire mark. I only use the center of the lane when switching between the left & right tire marks. As others noted the center of the lane can be quite slippery especially when wet.
Old May 12, 2011 | 07:32 AM
rhlhamlet's Avatar
rhlhamlet
Left of center in the left tire track most of the time.
Old May 12, 2011 | 07:37 AM
DLW_FLHTC's Avatar
DLW_FLHTC
Originally Posted by motorcyclelockman
When you are riding with no other bikes, where in your lane do you ride? I mostly ride close to the center line just to give me more available pavement to stay on in case things go bad. Just wondering what others do.
In whatever location gives the cages that I am concerned about the most visibility to me.
Old May 12, 2011 | 07:39 AM
Throwback's Avatar
Throwback
Like most, I tend to ride left tire track. When Traffic is stopped on a two lane road for say, someone ahead making a left turn, I like to get way left. Hopefully anyone coming up can see the cage in front and if they F*^@ up, a slight swerve to the right hopefully misses me. About the only thing that bothers me is getting rear ended.
Old May 12, 2011 | 07:40 AM
smokindave's Avatar
smokindave
I ride to the left of center except, when large trucks are coming my way, then I move way over to the right. Reason being, I have been hit by flying stones off the trucks as they pass. In fact, (this is the main reason) 4 years ago a cement truck coming at me in the other lane dropped a piece of hard cement off the truck hitting me in the shin, bouncing off my tank. I had to pull over because it hurt like a bitch. Read my signature.
Old May 12, 2011 | 07:44 AM
MattInFla's Avatar
MattInFla
Originally Posted by 2011 Road Glide Ultra
I tend to ride left of center in the left lane, and run fast enough to minimize time beside cars or in their blind spots. I also run a gear lower in traffic as it makes the Pro Pipe emit a sonic daze disruption...
Hate to break this to you, but in many years of driving large fire apparatus, I saw a lot of drivers ignore the crap out of loud sirens and air horns. Those folks won't notice your loud pipes at all.....
Old May 12, 2011 | 07:46 AM
HRLYSG's Avatar
HRLYSG
Originally Posted by Cme2c
In the left tire track line for increased visibility to the cages. Sometimes switching to the right track depending on the number of lanes, approaching intersections, etc. Basically position yourself to see and be seen. Center of the lane is generally to be avoided because it is more slippery.
Saved me some typing as I do the same.
cromagnon's Avatar
cromagnon
I run in the middle. Grease spot cuts down the road friction resulting in increased tire life span.
Old May 12, 2011 | 11:36 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Close to the center out of the oil so the cagers can't share the lane.
Old May 12, 2011 | 12:31 PM
MADHOG's Avatar
MADHOG
Pretty similar... I ride to be "seen" for the most part, especially around these caged zombies in Vegas.
