I just installed a 21 on my 09 sg. I went for a short ride around the block. When I put the bike back on the jack and have to put a lot of effort to spin it only 3/4 of a rotation. Is this normal? The wheel spins fine with the calipers off.
When I first put my 21" on way back when I had to buy another set of spacers. The stock Harley one's on my '05 are slightly different lengths on both sides. They both needed to be the same size and it was the longer of the two stock sizes. All is well now. Didn't even take it off the jack when installing. I backed the nut of 'til the wheel would spin properly with the calipers mounted. Once achieved I would see the gap between the spacer and fork slider. SO I am running two of the longer stock spacers (one on each side).
I helped a good friend of mine install an 18" wheel on his SE EG. He had the same issue. The wheel would not turn freely. It turned out he had a bent rotor. The wheels and rotors were new and probably damaged in shipping. The wheel should spin with a little drag but should still spin. Try taking off one caliper at a time. See if the drag changes. If you have access to a dial indicator check your rotor runout to. Usually spacing effects both sides at the same time. Are you sure you installed the spacers on the correct sides. Brembo brakes are far less forgiving as far as spacing is concerned as well. Hope this helps.
I did same thing once and the new rotors were different. the old calipers were 11" and the brembos are 11 1/4 " . I would bleed calipers and check spacers also.
