Problem With My 2010 SG
Old May 20, 2011 | 11:43 AM
jschneider's Avatar
jschneider
3rd Gear
Default Problem With My 2010 SG
Left for work this morning and was about a mile from the house when my engine light came on and I had no throtle. Tried shuting it down and restarting but no luck but was able to idle it the house. Any body else have this happen?
Old May 20, 2011 | 11:50 AM
PistonPuller's Avatar
PistonPuller
Sounds like you went into limp mode. You need to do a diagnostic code search and see what code your bike through. There is a procedure on this board on how to run a search. You may be able to reset or at the least find out what threw the code
Old May 20, 2011 | 11:52 AM
camsmith's Avatar
camsmith
Sounds like what my 08 did. "Fly by wire" throttle position sensor trouble. Funny cable in my 07 and previous years NEVER gave trouble. Cycling ignition switch on and off four times with handlebar in "RUN" cleared the code on mine.
Old May 21, 2011 | 06:17 AM
luc.who's Avatar
luc.who
I had this problem on my road king, the plug behind the AC was loose. There are many posts about the limp mode, as someone else said, could be the throttle position sensor.
Old May 21, 2011 | 06:23 AM
Iceman24's Avatar
Iceman24
Probably bad TPS (throttle position sensor) - time to visit dealer for warranty repair.
Old May 21, 2011 | 09:46 AM
Sam2010's Avatar
Sam2010
POST # 2
https://www.hdforums.com/forum/touri...with-this.html
Old May 21, 2011 | 10:49 AM
speakerfritz's Avatar
speakerfritz
you know....this is the kind of stuff that needs to be put into a "sticky".
Old May 21, 2011 | 11:22 AM
Guntoter's Avatar
Guntoter
I see in this thread, the prevailing opinion is "throttle position sensor". In the thread from a a week or so ago the prevailing opinion was "ECM connector pins". with basically the same problem being described.
Old May 21, 2011 | 11:31 AM
The Guardian's Avatar
The Guardian
One word. Warranty.
Old May 25, 2011 | 11:08 AM
jschneider's Avatar
jschneider
3rd Gear
Update!! Took it to the dealer and they replaced the pins. I asked if this will happen again and was told that they have changed the design and have not had any more problems after the repair. Lets hope so!
