4509 driving lamp
Old May 20, 2011 | 02:57 PM
robfaulkner's Avatar
robfaulkner
Default 4509 driving lamp
For those folks who installed the 4509 aircraft 100w lamps in their driving light housings - are there any wiring issues? Does the existing harness and switch handle the added wattage, or was a relay needed. Thanks!
Old May 20, 2011 | 05:39 PM
Mick's Avatar
Mick
I have not done this mod , but here's a couple thoughts on it.
A 100 watt bulb at 13 volts is going to draw about 7.69 amps each.
You only have a 15 amp fuse for the circuit (I think) for the passing beams.
This would put you slightly over max draw for the circuit.
Another thought would be that you should have at least a 12 gauge power lead to the switch and 14 gauge to each bulb for voltage loss.
The stock wiring is smaller than this.
The best (and safest) way to do this would be to install a relay controlled by the stock switch , which will have it's own power source (and wiring gauge) to each light.
This guy makes some great stuff.
http://www.easternbeaver.com/Main/main.html
His stuff is motorcycle grade , water and vibration proof stuff.
You can generally go to about 50 watts each on the passing beams , I run 37.5 watts each and it runs safe with stock wiring.
Be careful going much higher with stock components.
Mick
Old May 21, 2011 | 05:36 AM
robfaulkner
Mick. My FLHTP has 4411 bulbs (replacing the blue and red bulbs) and I need to replace them with something much better. Rewiring and adding a relay doesn't bother me but if you have a bulb suggestion I'd be happy to have it. I bought the 4509's without checking fuse capacity or the wiring. Rob
Old May 21, 2011 | 09:47 PM
Mick's Avatar
Mick
I run standard Wagner 4415A sealed beams in my passing beam housings.
I like the amber look and they have a very flat,wide,pattern to them.
I figure they get me noticed better in the daylight and the beams are pretty good at night also.
These are 37.5 watt and setup for screw terminals.
If you like the clear look , the 4415 would work nice also.
Just my personal preference and safe with the stock wiring.
I have the original passing beams if you want to try them , just PM me and I'll see what shipping would be to Nova Scotia from New York.
Mick
Old May 22, 2011 | 06:41 AM
troop's Avatar
troop
Mick
I just ordered a set of yellow 894's for the spots. Looking forward to getting them installed...
kneesinthebreeze24
Mar 11, 2018 06:33 PM
Hogpro
Jan 6, 2013 02:20 PM
OldNavy66
Electrical/Lighting/Alarm
Jan 23, 2012 09:18 PM
Softtail Bob
May 8, 2006 02:12 PM
harleybob
Feb 6, 2006 08:42 PM
