Passenger Footrest Pivot Pin Removal
Old 05-21-2011, 04:03 PM
larsfum's Avatar
larsfum
larsfum is offline
Default Passenger Footrest Pivot Pin Removal
I am stumped on this one. Need to remove the footpads from the mounting brackets on my passenger footrests. Looks like it should be easy to remove the pivot pins, but they do not budge. I do not see a retaining clip on the pads, nor in the schematic. Can someone that is wiser shed some light on this?
Old 05-21-2011, 04:08 PM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
Remove the E Clip on one end of the pin also don't lose the spring steel plate.
Old 05-21-2011, 04:27 PM
larsfum's Avatar
larsfum
larsfum is offline
I don't see any clips anywhere on here. Can you tell me where the E clip is located? Is it on the pin under the pad, or between the footrest, and mounting bracket?
Old 05-21-2011, 05:31 PM
hockey8787's Avatar
hockey8787
hockey8787 is offline
when the floorboard is in the up position is their a chrome cover on it if so you need to take that off to get to the pin and spring!!
Old 05-21-2011, 05:34 PM
hockey8787's Avatar
hockey8787
Old 05-21-2011, 07:59 PM
TWIN CAM 96
My understanding it was a footrest not a floorboard. Footrest = footpeg
Old 05-21-2011, 10:36 PM
hockey8787's Avatar
hockey8787
Oops my bad!!
Old 05-22-2011, 02:21 AM
Wibbo's Avatar
Wibbo
Wibbo is offline
They can be a little tricky to remove, the rubber floorboard pad is held on with two rubber mushroom shaped nubs that are pulled through the bottom piece.
Remove chrome cover if you have them, pry up the rubber insert carefully
shim it up at each end so you can work without tryin to keep the insert raised.
NOTE: dont pry it up so far that the mushrooms pull through.. then yer ****ed
I used an allen wrench and poked the pivot pins outwards, take care not to lose the little detent ball and spring.
Old 05-23-2011, 03:15 PM
larsfum's Avatar
larsfum
larsfum is offline
Wibbo has the right part that I am trying to remove. Sorry, they are passenger floorboards. (Drawing calls them footrests) No chrome to remove. I am sure that there is a retaining clip there somewhere, as the pivot pins will not budge, but I'll be D@*#ed if I can see them. I can't even locate them in the drawing.
Old 05-23-2011, 03:44 PM
2011 Road Glide Ultra's Avatar
2011 Road Glide Ultra is offline
IIRC, the rubber insert locks the pin in place - no e-clip to remove. Had there been, I'm almost certain I'd remember chasing one of those little SOBs across the garage... Also IIRC, the spring for the detent ball is held in by the pivot pin, so it applies sideways pressure on the pin, which causes some binding. I used a large set of curved needle-nosed pliers to grab the pin and work it out through the hole on the floorboard you can see on the right in the photo above. Be ready to chase the detent spring. BTW, I was replacing the mounting brackets to raise mine a couple inches, and found it was a lot easier to remove the bracket from the bike first, then pull the pin - as shown in the above photo. The service manual said the other way around....
ac73
General Topics/Tech Tips
05-03-2018 07:42 PM
firefox23508
07-10-2016 10:52 AM
TimLScheffer
07-15-2014 04:55 AM
chevypilot
08-19-2011 12:37 PM
GodFather
07-05-2009 06:05 PM
Quick Reply: Passenger Footrest Pivot Pin Removal
