compresion testers
Old May 23, 2011 | 03:26 PM
jackinthebox's Avatar
jackinthebox
Default compresion testers
I would like to do a compression check on my bike. Which ones are you guys using. Can I get one from like sears? And is it pretty easy to do? THX
Old May 23, 2011 | 03:43 PM
KCFLHRC's Avatar
KCFLHRC
Harbor Freight sells them. Remove the spark plug, screw it in and turn the motor over. That's all there is to it.
Old May 23, 2011 | 03:44 PM
07RoadHawg's Avatar
07RoadHawg
Yep. I got mine from Amazon for around $20 with a few different adapters should I need to check compression on some other engine in the future.
Old May 23, 2011 | 03:57 PM
djl's Avatar
djl
Sears sells a good one; don't know who the manufacturer is. Regardless of where you buy, the guage is where the money is. Scrimp on the price and you scrimp on the quality of the guage and you will get inaccurate readlings that may cause you to take action that is completely uneccessary, or, false readings may mask a real and developing problem. So, if you need to spend $50-$100 to get a good one, spend it. I can site several instances where a cheesey guage and false readings led the owner to make decisions that were not warranted.
piasspj's Avatar
piasspj
They are not expensive and are easy to use. Get one with different sizes of threaded adapters.
Avoid the ones with a rubber tip that you press against the hole. It isn't easy for one guy to hold it and crank the motor.
Old May 23, 2011 | 05:42 PM
jackinthebox
Thx for the info guys. I think I have a coupon for sears so I'll go check them out first.
The Cheesehead
Apr 7, 2015 06:46 PM
Little devil 14
Jul 17, 2013 06:22 PM
junkyardscrounger
Exhaust System Topics
Aug 4, 2011 01:59 PM
Woods Glen
Oct 27, 2010 12:29 PM
WHOSNEXT
Jan 15, 2009 08:06 AM
