fuel moto
Old Jun 2, 2011 | 07:01 PM
Tek74's Avatar
Tek74
Originally Posted by The Q
If purchased from Fuel Moto, call Keith or Jamie at Fuel Moto. They will listen to your friends problems and walk them through possible fixes. I had a decel pop problem when I got my PCV and Keith had me fixed in less than five minutes.
I'm having the same Deceleration pop problem and need to call them. Just out of curiosity, what was your 5-minute fix?
Old Jun 2, 2011 | 07:02 PM
cdestuck's Avatar
cdestuck
I'm so surethey will fix you up, great support from these guys. Had some bad pinging and they sent me a new map and bingo. Runnin great.
Old Jun 2, 2011 | 11:56 PM
The Q's Avatar
The Q
Keith had me put "5" in the 0% Throttle range from 1750 to 6500 RPM. Fixed it just like that. Keith said you can go up in increments of 5 or down the same.
Old Jun 3, 2011 | 12:49 AM
BBStacker's Avatar
BBStacker
Fuel moto will bend over backwards to help ya. If you or your "friend" choose not to follow or use their suggestions.... Well, I don't know what to tell ya!
Old Jun 3, 2011 | 07:18 AM
o-matt's Avatar
o-matt
Originally Posted by Sash302
I just call one of my friends and he said that he call Jamie and explain everything,and he told him hmmm that strange,give me your information and ill send you a new map,I mean that's cool that Jamie offer to help on some way.
my friend gonna stop by tomorrow in my house and Ill hook up the bike to the computer and check the tps if that's o.k ill check the connections to make sure everything is ok,also ill pool a map from power commander site and reload the pcv,I bean having a great luck with their maps,I hope i will get his bike to run good again.
Hey whiz kid, it's called TROUBLESHOOTING. Jamie is starting with the most likely cause of the issue and will work from there. He can't assume that the map is perfect, or that your friend didn't mess with the one he originally set up, or that he didn't load a new map accidentally. After your friend gets the new map loaded, if he's still having problems, Jamie can start looking at other possible problems.
If you want FuelMoto's help, let them help, don't go screwing with other maps and stuff.
Old Jun 3, 2011 | 07:49 AM
Will CF's Avatar
Will CF
I couldn't have said it better .... They always answer the phone... Send modifications within a short time of when you talk to them... It takes less time than B!tching about it on a public forum !!
Old Jun 3, 2011 | 08:05 AM
Pass's Avatar
Pass
OP: First, English, man... English. I can hardly understand what you're saying. Second, FM and Jamie are great peeps! They will help your friends, all your friends need to do is pick up the phone or send emails and follow the instructions. That's it. Trust me, I've been working with FM and Jamie to solve my detonation issues for a while now and they are top notch!!! If they can not only tolerate, but continue to answer, all of my inane questions and deal with my pestering... Then they are beyond good to go. Not to mention they really do know their ****!!!
So do what EVERYONE in this thread has said. Call FM and let them help. They back up their product 100%
Old Jun 3, 2011 | 08:13 AM
rg_dave's Avatar
rg_dave
Follow the instructions! Load the new map then call them if it does not solve the problem. There are a ton of things your friend could have done to screw up the install although its so easy a cave man could do it. Bend a pin and your screwed.
Old Jun 3, 2011 | 09:07 AM
103 sedona orange's Avatar
103 sedona orange
I like the WHIZ KID thing. Whenever you/anyone/ your friends do mods "**** CAN HAPPEN" Why don't your friends call Jamie themselves???? Who knows "WTF" happened!!! maybe your "BROHAMMIES" did something wrong. Just my 2 cents.
Old Jun 3, 2011 | 10:15 AM
Rickr01's Avatar
Rickr01
My Fuel Moto PC-V runs perfect. It was plug and play.
